Go to Post Doctor the drill, or doctor your hand. Easy choice. Let's all make the right one. - Molten [more]
Unread 23-03-2004, 22:15
dddriveman's Avatar
dddriveman dddriveman is offline
Former Driver 1038, 979
AKA: Driveman
FRC #1038 (Thunderhawks)
dddriveman has a spectacular aura aboutdddriveman has a spectacular aura about
Send a message via AIM to dddriveman
Help!!! 979 has no autonomous day before Buckeye
I have tried for sleepless nights to get our autonomous mode to work. IT is simple we pulled it right off of kevin.org. Since nobody on my team knows anything about c we cannot get it to work correctly. Could someone get it to work for me and then explain how you did it. i will attach it in zipped form
"I'm sorry, after all he is just a wookie!"
Unread 23-03-2004, 23:09
10intheCrunch's Avatar
10intheCrunch 10intheCrunch is offline
Who's John V-Neun?
AKA: Alex Baxter
None #0254 (Cheesy Poofs)
10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough
Send a message via AIM to 10intheCrunch
Re: Help!!! 979 has no autonomous day before Buckeye
Could you explain a little more about what problem you are having? Is there a compile error, a code error, is it just not doing anything? I flipped through the code *real* quick, and it looks like this isn't currently set to run in autonomous mode, but when you click p1_sw_trig...try toggling that and see what happens.
Good luck,
~Alex Baxter
Programming, Arms operation, Team 254
Unread 23-03-2004, 23:12
REVving up for a new season
FRC #2848 (All-sparks)
come over to 73's pits sometime during the comp and we will get you all squared away
Unread 23-03-2004, 23:21
dddriveman's Avatar
AKA: Driveman
we cannot get it to run our autonomous mode it just say something like ifi_userintilization started. and then do nothing
Unread 23-03-2004, 23:24
A team with no working autonomous code is offering to help another team with no working autonomous code?
Unread 23-03-2004, 23:46
oh come now joe...you know very well it will be working just fine by our first match and jeff will be giddy as he will have stayed up all night....
Unread 24-03-2004, 05:40
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
I'll offer 1317's pit too. (And our's works!)
--EDIT--
Oh, yeah. We wear a crazy orange... We pit has a giant banner with lightning and a laser and our logo, which has "DF" in it.
--EDIT--
Try Greg first though. We didn't use the beacons, so I don't know much about how to use that code. I will say that it doesn't appear to have any outputs ever.
Unread 24-03-2004, 07:35
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
How do you GET to autonomous? we had a prob last night, I changed main.c AND user_autonomous. user_autonomous has its own loop.
Unread 24-03-2004, 08:59
Programming User
The competition port sends the signal that sends you into it. Is that what you mean?
Unread 24-03-2004, 10:30
Who's John V-Neun?
AKA: Alex Baxter
Theres a competition pinout guide on the IFI website that will show you which pins to bridge to put the bot in autonomous. You can also manually do it with a digital or analog input in your program...
~Alex Baxter
Unread 24-03-2004, 10:48
AKA: Jamie Bliss
No, to simulate.
What I did was change main.c so it calls Process_Data_From_Master_uP() once and then goes into Autonomous.
You also have to change User_Autonomous() so that ITS loop doesn't exit immediately. Change the while (Autonomous_Mode) to while (1)
Unread 24-03-2004, 12:16
Who's John V-Neun?
AKA: Alex Baxter
Probably (much) better to simulate it by bridging the pins or setting it up in the program, rather than hardcoding the robot to autonomous (you don't want it to go crazy uncontrollably when you turn it on).
~Alex Baxter
Future of Autonomous Mode FadyS. Programming 41 24-05-2004 19:45
A better autonomous method.. randomperson Programming 4 24-02-2004 18:02
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Favorite Michael Jackson Song Mullet Chit-Chat 7 13-02-2003 20:39
Autonomous Kill Switch UCGL_Guy Programming 8 15-01-2003 17:39
