Dave's right, the compiler is complaining about line 367:
if (drive_timer > LOST_TARGET_TIMEOUT)
But the compiler output appears to be truncated. It's supposed to tell you what name it doesn't recognize. There might be an invisible character in the source file on that line, which the compiler would choke on and be unable to display. The easiest thing to do at this point would be to duplicate the line, character by character, without doing a copy/paste, then delete the original line and try compiling again.
If that doesn't help, then show us the section of the header file where LOST_TARGET_TIMEOUT is defined (probably in navigate.h).
(Oh, and next time you need to post programs here, surround it with [
CODE] and [
/CODE] so the formatting is preserved.)
