Go to Post Welcome to ChiefDelphi a month before Kick-Off. This is an annual traditional experience for quite a few regulars. - synth3tk [more]
Unread 24-03-2004, 12:30
Re: What is wrong with this code???? It won't Compile and I don't know why? Please He
Originally Posted by Biff
This C stuff is new to me, but the { }'s around line 367 I can't figure out if they all make sense, I think you may have some that are unmatched. Hope this helps
Oh, my. There's certainly something odd going on:
case DR_BOTH_CENTER:
    Navigator_State = AT_TARGET; // Both servos are within the target threshold
    printf("AT_TARGET\n");
    break;
    else
        // We are not locked on - Stop
        // give the trackers a chance to catch up
        left_drive_set = LSTOP;
        right_drive_set = RSTOP;
        drive_timer++ ;
        if (drive_timer > LOST_TARGET_TIMEOUT)
            Navigator_State = TURN_TO_TARGET;
            printf("TURN_TO_TARGET\n"); // Done driving to center
            left_servo_set = 127;
            right_servo_set = 127;
    break;
There are three }s in a row right before a naked else statement. This source code is apparently missing a few lines, including an if.
There is also a case statement commented out near the top of the big switch. That can't be doing what you want, can it? If you want to "skip" that state, as the comments suggest, I think you need to initialize your state variable to DRIVE_TO_CENTER instead of WAIT_TO_DRIVE in line 37.
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
Printf warning during compile? actorindp Programming 4 20-02-2004 17:02
How to measure execution time? And code size? gnormhurst Programming 17 17-02-2004 08:06
Can't Compile the Default Code pressurex1 Programming 4 25-01-2004 20:26
Problem with FRC Default code AsimC Programming 2 11-01-2004 19:22
