Go to Post so this is going to sound really dumb but remember that i am a mechanical guy. - Greg Needel [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 21-03-2004, 11:19
IMDWalrus's Avatar
IMDWalrus IMDWalrus is offline
This is a line...
AKA: Paul
FRC #0818 (Genesis '02)
IMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to behold
Send a message via AIM to IMDWalrus
Building a Clock with Periodic Motion
I need help with my homework; I figured that the engineering geniuses at CD would be good people to ask for help.
For one of my classes, I've been assigned to build a clock. To be honest, I have no idea how to do this...so I'm asking for any assistance that you can offer me.
The clock has to be able to keep track of time fairly accurately - within one second for a 30 second trial, and within two for a two minute trial. If I can get the clock to accurately measure three minutes as well, I get extra credit.
Problem is, there are a few catches...
1.) The clock can't make any use of electrical components
2.) The clock has to involve some form of periodic motion
Once the clock has been set into motion, I'm only allowed to touch it twice. The thirty second and two minute trials don't need to be measured during the same run; I can do thirty seconds first, reset, and do two minutes.
I'd like the clock to be unique; I've considered using one of those dipping birds but have no idea how to tie that into a timekeeping mechanism.
Any suggestions? The project is due on Friday, and I want to have some time to test it. Any help at all would be appreciated...
[edit]Slight clarification[/edit]
Unread 21-03-2004, 11:22
Re: Building a Clock with Periodic Motion
what do you mean it cant have any mechanical components?!
any physical object is a mechanical component
can you be more specific about the rules and limitations?
try a sundial that straps on to your wrist
yeah.. i wasnt being serious
Unread 21-03-2004, 11:25
IMDWalrus's Avatar
This is a line...
AKA: Paul
Wow...it's too early for thinking. That didn't make much sense; I'll give it another go here.
"Machines are to be constructed from cardboard, wood, plastic, rubber, springs, etc. Electric motors are not allowed."
For some reason, I've been thinking that meant all mechanical components are not allowed...which is not only not what I've been told but also makes zero sense.
Unread 21-03-2004, 11:29
wow you could have some fun with this!
water - sand - windup things - stuff that flys
how about this - get a bowlingball, some string, and a candle.....
this is one of the drawbacks of being on a FIRST team - your teacher is going to expect something incredible from you :^)
Unread 21-03-2004, 11:32
Swan217's Avatar
Swan217 Swan217 is offline
RoboShow Producer
AKA: DJ Royal Fusion
no team (RoboShow)
Swan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond repute
Send a message via AIM to Swan217
Try water dripping into a graduated cylinder - water drips at a fairly constant rate, as you'd know if you've ever had a leaking faucet.
Orlando Regional Planning Committee & Cohost of The RoboShow & RoboVision
Follow The RoboShow on Twitter @RoboShowLive & check out our website, www.theroboshow.net
Follow RoboVision on Twitter @RoboVisionOD & check out our website, www.robovisionod.com
"As president, I believe that robotics can inspire young people to pursue science and engineering. And I also want to keep an eye on those robots in case they try anything."
— President Barack Obama
Unread 23-03-2004, 10:04
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
at first i was going to suggest using my incredably accurate stopwatch i did for some coursework
ok, why dont you try working out the time for a pendulum and just use it and count the swings, you could easily work out one second iirc...
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 23-03-2004, 11:05
if im reading the problem correctly, he has to make a clock with a 30 second period - something you trigger and it runs for 30 seconds, then some end condition happens
making a pendulum that takes 30 seconds to swing once would be, ummmm.. big!
Unread 23-03-2004, 11:43
Duke 13370's Avatar
Duke 13370 Duke 13370 is offline
C is for cookie...
#0862 (Team Lightning)
Team Role: Webmaster
Duke 13370 will become famous soon enough
Send a message via AIM to Duke 13370
The way a normal grandfather clock works would work for the task, but it takes time to create and test. Basically, there would be a large pendulum that swings back and forth (probably once every other second). when it swings in one direction, it trips a lever, advancing some sort of counting mechanism (like spinning an arm X degrees or pushing a beam X cm).
or, you could just build a pendulum and count the swings yourself if it's allowed.
Name:	clock thing.JPG
---Lightning Robotics!---
Unread 23-03-2004, 14:12
Eric Bareiss's Avatar
Eric Bareiss Eric Bareiss is offline
It's a Bird
AKA: BoogyShoes
FRC #1492 (Team Caution)
Eric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of light
Send a message via AIM to Eric Bareiss
Does the clock have to show time or can you just count the number of times the pendulum swings.
Unread 23-03-2004, 17:05
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Funny thing as I remember the rate that a 1 meter pendulum swings is once per second, you then need a escape mech to drive it and to count and your home.
Unread 24-03-2004, 11:48
IMDWalrus's Avatar
This is a line...
AKA: Paul
It doesn't have to show time; counting pendulum swings will work.
Unread 24-03-2004, 14:53
It's a Bird
AKA: BoogyShoes
Biff is right, a one meter pendulum should swing with a one second period no matter how many times it swings. There is a simple equation to find the period of a pendulum.
I don't know it off the top of my head, but I can imagine that you should because it is your class.
First step is going using the equation to be find a pendulum that swings exactly one second. If you build it right it should easily be accurate for 2 minutes.
Unread 24-03-2004, 16:05
Rafi A Rafi A is offline
AKA: Rafghan
FRC #0935 (RaileRobotics)
Rafi A is on a distinguished road
Send a message via AIM to Rafi A Send a message via MSN to Rafi A Send a message via Yahoo to Rafi A
i beleive it is:
period=2*pi*square root of (length/acceleration due to gravity)
Unread 24-03-2004, 16:19
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Did someone say CLOCK??
