Go to Post This is where a tenacious NEM comes in very handy. - Mark McLeod [more]
Unread 24-03-2004, 20:46
Crebb's Avatar
Crebb Crebb is offline
AKA: James M.
FRC #5279 (Bionic Eagles)
Crebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud of
Re: Drawing #35 Chain
I found an ipart of a chain and tried to assemble it in inventor. It took about 20 minutes to make about a foot's worth of chain. It also made the computer run very very slow. Instead of using chain I just made a rotational constraint between the 2 sprockets that the chain would have gone between. It may not look as realistic, but it works.
Shibuya Hoppmann, Mechanical Engineer
VCU School of Engineering 2012
Team 5279 2016-Present
Team 384 2003-2015
Globe motor dimension drawing jskene Motors 0 15-02-2004 13:34
chain ridding up and off sprocket problem... davidhoare Technical Discussion 4 04-02-2004 10:13
25 or 35 chain? Alan Ing Technical Discussion 24 02-03-2003 13:56
1/4" chain and links from small parts archiver 2001 2 24-06-2002 00:18
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
