Go to Post Our behavior – both good and bad – is contagious. Set a good example, behave in a mature, reasoned, professional manner and we will find that others around us will too. - dlavery [more]
Unread 25-03-2004, 20:35
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Re: helical gears
Could you explain how they eliminate those problems? I see how they eliminate axial thrust, but other than that, they seem to be equivalent to helical gears. They look pretty sweet though
Never mind from what I have read they only eliminate axial thrust. Though that is better than going through 50 plastic gearboxes. I should never reply to something when I am sick. Anyway what are hypoid gears? Just a question since we are talking about helical gears.
What type of steel are gears commonly made from? Matt Adams Technical Discussion 5 02-01-2004 23:19
helical gear info mickjagger Technical Discussion 4 02-02-2003 10:16
Helical gears that come with new drill motor Joe P Technical Discussion 4 12-01-2003 11:09
helical gears efficency Andrew Dahl Technical Discussion 0 07-01-2003 13:02
Need help! What kind of gears are we allowed to use?? Randy_Ai Technical Discussion 3 23-01-2002 22:56
