Go to Post Monkeys with typewriters will eventually create shakespeare, and spam bots will eventually create a thread title that fits the rumor mill. - rtfgnow [more]
Unread 26-03-2004, 02:16
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Lightbulb 2X Ball Into the Ball Release
Let's say you're a robot and you want to get rid of the 2X balls. You have to cap a goal. If you place a 2X out of the playing field it will be returned. But what if your team wanted the ball out of the game. You could put it into the ball release, no?
Unread 26-03-2004, 02:36
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: 2X Ball Into the Ball Release
You could try, but if I remember correctly, the gate that holds the balls into the corrall stays open after the balls drop, so it would just roll back down.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 26-03-2004, 02:47
Carpe diem
Cory
The gate does stay down. However, I think you could actually place the ball right on the gate. The gate looks to be be parallel with the floor and not angled down (like it probably should). This issue caused problems at the BAE regional, a volunteer would have to shake a support pole violently to try to get stuck balls to fall onto the playing field.
Unread 26-03-2004, 05:09
Elgin Clock's Avatar
FRC #0237 (Black Magic)
I believe at all the regionals I have attended (re: NJ, and UTC) that the door on the corral fell and was perpendicular with the playing field (darn gravity).
I guess your field up in BAE must have been broken!!
I think that also if you try to put the ball up there, then that would be considered going out of bounds and may be at the ref's discretion to disable your robot.
Unread 26-03-2004, 10:18
moogleslair moogleslair is offline
#0021 (ComBBAT)
moogleslair is on a distinguished road
Send a message via AIM to moogleslair
UCF's field the door fell to a horizontal position. Either way back to the begining of this thread. It would be really hard to balance that ball there.
may i ask..
..WHO DAT BBAT?
2003 UCF Spirit Award Winner
2003 UCF Sportsmanship Award Winner
2003 UCF Quater-finalist (thx 456 & 94)
Unread 26-03-2004, 10:43
Aaron Lussier's Avatar
Aaron Lussier Aaron Lussier is offline
Volunteer for hire
Aaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to behold
Mike,
I was on Field Reset all three days at BAE, the only day we needed to shake the pole was on Thursday, the pratice day. All other days it worked flawlessly to my receloction.
-Aaron
Team 151 Student/Mentor 2001-2004
US Navy 2005 -2009
Volunteer 2010 - ???
Field Reset Extraordinaire
Unread 26-03-2004, 10:57
Carpe diem
Attached is a pic of our drive team in operation in Annapolis. You get a pretty good shot of the ball release. For the purpose of this thread, let's assume that the ball release can support a 2x ball. Is it a good strategy, or even legal?
Unread 26-03-2004, 19:36
The only rule I would be concerned with is The out of bounds rule that I previously mentioned.
It may also be deemed a safety issue as well. We very well don't want a robot to drop the ball over the wall and on to the drivers while trying to put it up there.
That is, if you COULD do it with the door being how it is.
Unread 26-03-2004, 19:42
Carpe diem
Right, you would be going out of bounds. But doesn't the rule allow you to go out of bounds? I think you are only disabled if your robot touches the ground or there is a safety concern.
Unread 26-03-2004, 19:58
Cory's Avatar
AKA: Cory McBride
A rule states that a robot may not cross the top of the 7' wall. I would assume that since the big ball is part of the robot, when being held by it (As I recall from an update/Q&A, I think), they would disable your robot for crossing the plane of the 7' wall.
Cory
2001-2004: Team 100
Unread 26-03-2004, 20:01
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
The out of bounds rule says if your robot has to put force on something outside the playing field to return to play it will be disabled. Its pretty much reffering to landing on the carpet outside the field or getting a hook stuck on the railing/steel cable, etc...
The time it would take you to balance the ball up there is probably not even worth it, why not just push the ball deep into a goal if you want it not to be used?
The ball is an extension of the robot when its being held, so according to that you would be disabled.
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 26-03-2004, 20:05
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I beleive it is illegal to reach into the ball release, in the rule dealing w/ the ball corrals it says it is illegal to break the plane of the diamond plate, which in theory, extends into infinity. So I doubt you are allowed to reach into the ball realease. Also, teachnically that is out of bounds, and all large balls going out of bound must be returned...
Unread 26-03-2004, 20:10
Ahh, the prodigal son speaks.. And it actually makes sense.
Yeah, that sounds about right, even if you were able to do that, it would more than likely be returned back into play.
It was a good idea while it lasted though.
Carpe diem
Cory
And the dream dies. Thanks Cory and everyone else for your help. The second you think you have found a loophole in the rules, FIRST is already two steps ahead.
Unread 27-03-2004, 19:11
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
You would also at least get a 10pt penalty for crossing the plane of the player station. If not disabled because that would be deliberate it happened to several teams in the Midwest regional I remember 45 doing it a few times.
Lip at ball chute opening Doug Traster Rules/Strategy 1 19-01-2004 01:33
ball activation Martin Rules/Strategy 9 12-01-2004 17:16
2004 Game BBFIRSTCHICK General Forum 112 19-04-2003 17:12
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
30" ball sits up there real pretty archiver 2001 18 23-06-2002 22:49
