Go to Post This slow-motion intro... Canada is rubbing their match cycle efficiency in our faces :( - PayneTrain [more]
Unread 26-03-2004, 18:02
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: best cpu
Originally Posted by TeknoBramha
Could someone tell me what is the minimum you need to work with Autodesk and 3D Studio Max, thinking cost-wise? Also how much is needed to get the best(dont go to extreme, just for these two programs)? I am a bit confused, so place your opinions.
You could easily spend 5-600 dollars (no monitor) and run them pretty comfortably. To run them at pretty much peak performance, think upwards of 1100. Then to really run them, a system like this guy speced, at 1500. As you pay more and more, the increase in performance is less and less. Basically, when i buy tech stuff, i try to get stuff that is just over the first big bump in performance. After that, you are just spending your money on getting newer stuff. Personally, i dont think you should ever buy anything close to top of the line. You can always run any software on middling computers, you just need to upgrade more often, but it still comes out cheaper if you stay away from top end stuff.
Team 1257
Tether for new EduBot Controller gburlison Programming 9 18-12-2003 17:53
cpu ivanslost Programming 1 15-02-2003 23:23
Help picking motors Keith Chester Motors 10 21-12-2002 17:44
Q&A Watcher Available for Download Nate Smith General Forum 11 19-12-2002 11:12
Serious Controller Ideas archiver 1999 28 23-06-2002 23:01
