Go to Post I hate you.... in a graciously professional sort of way. - Uberbots [more]
Unread 03-03-2004, 13:28
HuskieRobotics HuskieRobotics is offline
HuskieRobotics has a little shameless behaviour in the past
Exclamation wiring and installing a light sensor
we need to know where the sensor wires need to be placed and how to program it
we also need to know the degrees of the sensor too for positioning
Unread 03-03-2004, 13:33
REVving up for a new season
FRC #2848 (All-sparks)
Re: wiring and installing a sensor
what kind of sensor?
Unread 03-03-2004, 13:38
the kind we need for following the white line
its also a banner brand
Unread 03-03-2004, 15:21
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
the banner sensors that first gives us are tricky little felers. the are IR, and have a built in source which makes it nice and easy. they run on 12v and out put 5 to a normaly open and a normaly closed output. in order to wire it do the following:
brown wire - this is the postitive. connect it to +12V
blue wire - this is the negitive. connect it to ground (on the battery)
black wire - N.O. wire
white wire - N.C. wire
you then can choose between N.O. and N.C. (it REALY doesnt matter). you connect the one you choose to the digital in. for our sake, were gonna say you plug it into digital input 10.
now to code it, in the code first you have to set it as an input. this is done for you in the default code:
digital_io_10 = 1;
(autonomus or otherwise) you can look at the variable every single loop by saying:
if(rc_dig_in10 == 1) {
 //do this if its ON
} else {
 //do this if its OFF
i hope this helps you
"You're not a real programmer until all your sentences end with semicolons;"
Unread 03-03-2004, 16:10
Thank you!!!!!
Unread 15-03-2004, 13:52
bstempi bstempi is offline
Captain
#0708 (Hardwired Hatters)
Team Role: Student
bstempi is an unknown quantity at this point
Send a message via AIM to bstempi
digital_io_10 = 1;
 //do this if its ON
} else {
but doesn't FIRST supply us with the red LED banner sensors? Do we wire these the same way?
Unread 15-03-2004, 14:28
the banner sensors are little yellow boxes with a red lens - they send out a pulsed infrared light, and look for it to be reflected back - usually the carpet will not reflect it, but the tape or white paint will
the little sensors FIRST gave us that are about a 1/4" square with three leads are infared recievers that are designed to pick up the beacon from the center of the field - there is a whole page of stuff on those on the innovationfirst.com website - under FIRST robotics / documents / beacon section
they are a little more complicated - you pretty much need to wire them to rc_dig_in_01 or 02 and use the interrupt flags to detect when they change state - also they need to be enclosed because they will pick up the IR signal from almost all directions the way they are.
Unread 26-03-2004, 10:49
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
Hello,
Can someone please kindly tell me if last year's banner sensors are allowed in this years competition
THnx
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 26-03-2004, 13:48
omega's Avatar
omega omega is offline
omega is an unknown quantity at this point
yes they are
Unread 26-03-2004, 19:21
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
They are allowed if they are available from Digikey, Future-Active, or Newark-In-One and you account for their cost.
