Go to Post Many students I have met will insist that nothing is better than FIRST robotics. And most people would agree that a ham sandwich is better than nothing. So does it logically follow that a ham sandwich is better than FIRST robotics? - tsaksa [more]
Unread 28-03-2004, 13:03
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
Goal blocking your corral? Not a problem anymore
At the Midwest Regional Drivers' Meeting on Thursday team #71 proabably asked the best question of the year:
"If a goal is blocking your chute can your human player use a 5 point ball to push it out? Since you aren't touching the goal, the ball is."
The refs didnt have an answer right away but they came back with this:
"It's legal, as long as the human player doesn't cross the plane into the field."
This helped out alot of teams.
Ricky Quinones
Director of Sales - VEX Robotics
Unread 28-03-2004, 13:07
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
Re: Goal blocking your corral? Not a problem anymore
But with 1 ball would you be able to push the goal far enough away to make a difference?
Unread 28-03-2004, 13:09
Ryan Albright's Avatar
Ryan Albright Ryan Albright is offline
Just Browsing
AKA: ryan albright
Ryan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond repute
Send a message via ICQ to Ryan Albright Send a message via AIM to Ryan Albright Send a message via MSN to Ryan Albright Send a message via Yahoo to Ryan Albright
That is very interesting, but the decision will prob be up to the judges of each regional.
Alumni of 710 2001-2004
Mentor 1083 2005
2005 UCF regional lead safety advisor
2005 Championship Safety advisor
Unread 28-03-2004, 13:10
MisterX's Avatar
MisterX MisterX is offline
Alumni
AKA: Mr. X
FRC #0521
MisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to behold
this was also brought up during the UTC driver's meeting were the refs only said that according to the rules a human player can not touch the goal nor pass the plane. There was nothing mentioned about a HP using a ball to move the goal in the rule book, just another loophole gone unnoticed.
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Probably not enough to push it far enough out to make a significant difference, but it will get it out enough to make it much easier for the driver to push the goal completely out and away. That's a really good question. I'll mention that to our human players.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 28-03-2004, 13:30
MisterX's Avatar
Alumni
AKA: Mr. X
FRC #0521
Like I said I am not too sure how much use this actually is. this was confirmed at UTC with being possible and legit yet I never saw any HP actually doing this. Just the logistics of it in trying to manipulate it to get your hand down there through the metal holder and not brake the plane I would imagine would be difficult unless you actually lie down and go at it like a pool stick but even then if you got a tall HP you might risk "stepping" outside the player station. plus in that two minutes your brain is goin so fast unless you are specifically thinking of this rule you will probably forget and focus more on pushing balls in your alliances corral to hand to you if you really are that good.
Unread 28-03-2004, 13:42
darkcreature darkcreature is offline
2005 Coach
None #0930 (M Cubed)
darkcreature is an unknown quantity at this point
Send a message via AIM to darkcreature Send a message via MSN to darkcreature
Cool Re: Goal blocking your corral? Not a problem anymore
In one of the SF rounds at the Midwest Regional I personally used a 5pt ball to move one of the goals away and if you push hard enough and fast enough the elasticity of the ball also helps to move the goal farther. Even though I did not get any more balls through the chute in that match, the goal was far enough away to get 45 or 269 to push us some more balls through the chute. Thanks guys for picking us as your alliance partner and assisting us to the top. That was too cool!
In every winner there are dozens of losers. Chances are you are one of them...
Unread 29-03-2004, 23:27
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
I saw it done a few times at Midwest this past weekend ... like Yan said, it made it easier for the robot to move the goal away from the corral - especially if it was jammed right up in that corner!
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 29-03-2004, 23:37
Vince lau's Avatar
Vince lau Vince lau is offline
Building robots since 1995
FRC #4914
Vince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond repute
Send a message via MSN to Vince lau
can use a ball to push another ball, to push the goal away?
Unread 29-03-2004, 23:43
Ryan F.'s Avatar
Ryan F. Ryan F. is offline
Ryan F. is a jewel in the roughRyan F. is a jewel in the roughRyan F. is a jewel in the rough
They could use it to push the goal away, but in the end I don't think it helped that much. Our human player tried it, but it didn't work too well. Also, if it took the robot to go and finish the job of moving the goal, they were probably wasting time they could have spent herding balls into the other chute.
Unread 01-04-2004, 16:30
Jensena's Avatar
Jensena Jensena is offline
#0269 (Cooney Robotics)
Team Role: Human Player
Jensena has a little shameless behaviour in the past
Send a message via AIM to Jensena
Thank God for that ruling it saved me once.
Unread 01-04-2004, 21:25
Jeremy L's Avatar
Jeremy L Jeremy L is offline
Videographer, Team 177
AKA: The Basket Maker!
None #0177 (Bobcat Robotics)
Jeremy L is on a distinguished road
Send a message via AIM to Jeremy L
this point is irrelevant. simply have the balls delivered to the other human player, and have that human player pass it to your human player. simple, effective, doesn't risk breaking any rules.
that's what we did anyway...
"Why is your team so successful?" "Two words: Good decisions."
"How do you make those?" "One word: Experience."
"How do you get that?" "Two words: Bad decisions."
Unread 01-04-2004, 21:40
Robohawk-master's Avatar
Robohawk-master Robohawk-master is offline
AKA: Barry
#1109 (Robohawks)
Team Role: Operator
Robohawk-master is on a distinguished road
not irrelevent... today I saw in the Can Reg practice one team who blocked both goals and we were stuck!
- Barry -
-2004 Canadian Regional Semi-Finalists
-2004 Bruce Power Safety Award
Unread 01-04-2004, 22:17
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
well if done correctly you can give the goal a hardy shove.. a strong enough human player would be able to send it gliding along its way.. it would be able to go far enough away that a robot would be able to wedge itself in to push the goal out. Or if it was a really good shove.. out of the way completely.
Especially if the human player is not worried about losing the ball (saying the team is an awesome coraller but not a great goal mover ) This is an awesome sort of loophole.. I will be exploiting this with all my alliances. Thanks for bringing it up!
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 02-04-2004, 06:54
AKA: Barry
#1109 (Robohawks)
Team Role: Operator
I just talked with the director of (at least our event) the Can Reg. He said he doesn't really see a problem, following that that you don't touch that goal or cross that line
- Barry -
Ball Corral blocking Thee_Mateo Rules/Strategy 19 01-03-2004 23:00
FIRST and Success: A Question of Definition Madison General Forum 70 27-11-2002 08:42
Small balls in 2001 competition archiver 2001 10 24-06-2002 03:59
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
I got answers from FIRST (Eric) archiver 2001 13 23-06-2002 22:33
