Go to Post However, the best responses come with patience. It might be a couple of days before you get a good answer or it could be 10 minutes. - Molten [more]
Unread 28-03-2004, 19:01
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
Re: Reducing wheel traction
we had this problem early on with our 6" (5" maybe?) pneumatic tires...our robot was walking as it turned so we used two pneumatic tires and two skyway wheels...
oddly enough we burn through pneumatic tires quicker this year then we did last year...and we havent damaged a skyway wheel yet...last year we were going through them every other match...
Unread 28-03-2004, 19:58
MOEmaniac's Avatar
MOEmaniac MOEmaniac is offline
The Crazy One
AKA: Steve
FRC #0365 (MOE)
MOEmaniac has a spectacular aura aboutMOEmaniac has a spectacular aura about
Send a message via AIM to MOEmaniac Send a message via Yahoo to MOEmaniac
The problem with the armor all is that it could be considered a contaminent to the field
When logic fails, force prevails!
2005 Record
Pittsburgh Regional: #1 seeded, Finalist - Thanks teams 808 and 869, Entrepreneurship Award, Sportsmanship Award, Website Award
Philly Regional: #2 seeded, Champions - Thanks teams 56 and 316, WFA Lou Rosanio, Chairmans Award
Nationals: Still to come
2004 Record
New Jersey Regional: Quarterfinalists - Thanks teams 25 and 103, Judges Award
Philly Regional: Quarterfinalists - Thanks teams 1370 and 1143, Imagery Award, Website Award, WFA Joe Perrito
Nationals: Galileo Finalists - Thanks teams 177 and 27, National Imagery Award
Unread 28-03-2004, 20:05
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
not that this could really help you right now, but in the future USE 6 WHEEL DRIVE.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 28-03-2004, 21:37
oreocookeee oreocookeee is offline
Critic Extraordinaire
AKA: orie
#0810 (Mechanical Bulls)
oreocookeee is on a distinguished road
Send a message via AIM to oreocookeee
my team has been having the same problem with turning. the solution that we came up with at the philadelpia regional was to use tie wraps covered by pneumatic tubing. we drilled holes in the sides of two of our beadlock wheels, fed the tie wraps through a few inches of tubing, and secured them by looping them around the tires and through the holes. we figured the judges wouldnt mind them as much since the tubing is smooth and wont damage the field. they allowed it, but they also told us that putting anything over the wheels will not be allowed at championships (nats; im trying to get out of the habit of saying that). it worked alright but it is just a temporary fix and we will probably consider replacing our wheels or something.
Unread 29-03-2004, 08:03
MrToast's Avatar
MrToast MrToast is offline
I named Greg Needel's cat!
AKA: Dave DeLong
no team (Rhode Warriors)
MrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud of
Send a message via AIM to MrToast
Wrap the wheels in duct tape. It's cheaper than pool hose...
(#121, 2004) Archimedes semi-finalists with 237 and 386! I had an awesome time guys, and thanks for the hat!
(#121, 2004) BC5 semi-finalists with 190 and 1027! Awesome time! We went further than I thought we could! Thanks for all your help w/ our transmission!
(#121, 2005) Galileo quarter-finalists with 47 and 203! Thanks for all your support through the stress!
If it moves and it shouldn't, use duct tape.
If it doesn't move and it should, use WD-40
"It'll all work out in the end, and if it doesn't, it's not the end." - Jeff Bullock
Unread 29-03-2004, 10:23
Matthew_H's Avatar
Matthew_H Matthew_H is offline
Ubergeek
#1028 (Ubergeeks)
Matthew_H will become famous soon enough
Send a message via AIM to Matthew_H Send a message via MSN to Matthew_H
On the FIRST Q and A they stated that duct tape could not be used on the tires.
We had the same traction problem and at St Louis we put tie wraps covering the wheel. One of the other posts stated that they were not going to allow tie wraps at Nationals. What rule does it violate and why would they change at the Nationals. It does not make much difference to us since we are not going to Nationals unless we win at Palmetto.
Matthew
Unread 29-03-2004, 10:53
Mark Pettit's Avatar
Mark Pettit Mark Pettit is offline
Addict
FRC #0991 (The Dukes)
Mark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to all
We did the vacuum hose and tie wraps thing. It allowed us to turn easier but we still bounced through the turns. Then we dropped the drill motors into low gear and it's smoooooooooth sailing for the Uncomfortable Hunk of Metal now.
Mark Pettit
Team #991 - The Dukes
Brophy College Preparatory
Phoenix, Arizona, USA
THE DUKES: Humans Competing In The Unlimited Class
Unread 29-03-2004, 11:00
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
In LA we did not allow tape as a traction altering device. Tape may be used as electrical insulator or as a non-functional decoration. Using it to alter traction makes it functional.
Zipties were allowed as long as there was no damage to the carpet. Since most were being used to decrease traction, this was generally not a problem. It is the knobs you use to lock the zipties that damage carpet. So by keeping the knobs away from the carpet, there were no issues.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 29-03-2004, 18:43
Dan9874123's Avatar
Dan9874123 Dan9874123 is offline
FRC #0236 (Techno Ticks)
Dan9874123 can only hope to improve
Send a message via AIM to Dan9874123
en contraire my friend, 10 wheel drive
"Better to remain silent and be thought a fool, than to speak out and erase all doubt"
Abraham Lincoln
Clamping wheel hubs sanddrag Technical Discussion 7 29-02-2004 00:20
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
traction questions AlbertW Rules/Strategy 2 05-01-2003 17:58
Friction, traction, torque - oh my... Gui Cavalcanti Technical Discussion 30 13-08-2002 18:01
