#16
Re: 2X Ball Into the Ball Release
Yeah if you break the plane of the 7ft wall with your robot or ball held by the robot, it's a 10pt penalty each time, not dq. We got that penalty twice in one match (within a few seconds of each other) due to a little craziness while driving in that area... No harm done... |
#17
I was watching those matchs thanx to the live web cast and it didnt even look like your fault a few times u were pused while holding the ball up there
#18
Looked more like the ball crossed the plane, not your actual arm--they changed the rules to say the yellow ball is only part of your robot in the cases of goaltending/assisting balls to goals. Hmmm....
#19
We also had a match where we were disabled due to the 2x ball in our arm touching the floor outside the field. Although the ref told us that was the reason we were disabled, I'm not sure that's right (2x not being part of our robot in that case). However, it probably would have been deemed unsafe anyways even though we probably could have gotten ourselves back up.... Oh well!! Life goes on... Edit - Found out we actually did touch the carpet with our robot arm, but it was also a safety concern for the volunteer crew sitting right there. Last edited by AmyPrib : 29-03-2004 at 11:03. |
#20
My reccomendation would be that the ball is not part of the robot. I can't even think of a situation where it would make sense to call the ball a part of a robot. |
#21
Caping your opponents goal as a successful way of goal tending. I don't understand how you can't allow goal tending, but you are encouraged to cap your opponents goal to raise your QPs. |
#24
Capping an opponents goal is completely legal to do, to prevent them from scoring balls. However, if your robot is still holding that ball and they shoot, bounces off the 2x you hold, it's goaltending. If you're fast enough to cap it before they can shoot, then it's perfectly legal. But you can't just hold the ball over the goal. I haven't seen many people do it, because the risk of goaltending is pretty high for the amount of time it usually takes for someone to cap anothers goal successfully. This is sorta getting off topic of the original thread though. All the rules/penalties have been discussed earlier, and I think they're pretty well written now in the updated version of the rules. I want to make sure at nationals about the rule of 2x ball being part of the robot. |
| Lip at ball chute opening | Doug Traster | Rules/Strategy | 1 | 19-01-2004 01:33 |
| ball activation | Martin | Rules/Strategy | 9 | 12-01-2004 17:16 |
| 2004 Game | BBFIRSTCHICK | General Forum | 112 | 19-04-2003 17:12 |
| Curie Division Robots information... (not complete) | archiver | 2001 | 3 | 24-06-2002 03:13 |
| 30" ball sits up there real pretty | archiver | 2001 | 18 | 23-06-2002 22:49 |
