Go to Post Then as soon as we get the kit loaded into the back of my truck, we ferociously rip it open screaming "How many CIMs!?" - sanddrag [more]
Unread 19-03-2004, 09:54
dude__hi's Avatar
dude__hi dude__hi is offline
Now a CSWA
AKA: Cristian Arcega
FRC #0842 (Falcon Robotics)
dude__hi is an unknown quantity at this point
Reducing wheel traction
I am from team 842 and we have been having problems with our wheels. We used the ones that came in the kit. We need to reduce the traction, is there anything we could add to the wheels to reduce the traction between the wheels and carpet? Please respond.
Powerpoint is a distraction, people use it when they don't know what to say...
2008 FIRST Chairman's Award Winner
Unread 19-03-2004, 10:11
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Reducing wheel traction
Go to your LHS and get some "sump pump hose" It is about $10 for 24 feet. (around here anyway) It looks like corrugated drain hose but is much softer and more flexible. Cut a slit down the side of that and zip-tie it over two of your wheels. Your robot will turn so nice you won't believe your eyes.
If you have durability problems with that you can use a sturdier "pool vacuum hose" which is a harder material but stil just as flexible. It is a bit more expensive at $1.10-2.60 per foot. This will give increased durability and forward traction over the sump pump hose but sideways traction with this material is not as good but still much better than just tires.
Unread 19-03-2004, 23:09
CyberWolf_22's Avatar
CyberWolf_22 CyberWolf_22 is offline
Programming and Electrical Mentor
AKA: Allen Gregory
FRC #2587 (Afrobots)
CyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really nice
We put zip ties on our wheels.
Unread 19-03-2004, 23:37
Roland's Avatar
Roland Roland is offline
Post-A-Holic
#1466
Team Role: Webmaster
Roland is infamous around these partsRoland is infamous around these partsRoland is infamous around these parts
We cut the rubber off some 8" (I think) Skyway wheels and milled horizontal slots into the sides. They have great traction going forward, but turning from side to side is smooth as silk. I saw a lot of zip tied wheels in the regional webcasts I watched.
Unread 19-03-2004, 23:57
Gabriel Gabriel is offline
#1409 (Fightin' Llamas)
Gabriel is just really niceGabriel is just really niceGabriel is just really niceGabriel is just really nice
Send a message via AIM to Gabriel
We struggled with this problem as well.
At UTC zipties were allowed to be wrapped around the wheels, but if the robot stalls and the refs see damage to the carpet they will make you take off the zipties.
UTC Refs will also allow you to wrap tape around the wheels as a traction device but NOT as a fastener. This interpretation seems a little weird to me so I don't know if it will be allowed at every site.
Velcro is NOT allowed.
The best idea is vacuum cleaner hose, which I believe was called sump-pump hose earlier in the thread. Team 500 was generous enough to supply us with a lot of this stuff.
Remember, this will probably change your traction significantly so your driver will need a lot of practice to readjust and your autonomous mode will need to be recalibrated.
Unread 26-03-2004, 18:23
S.Nickens's Avatar
S.Nickens S.Nickens is offline
Morpheus
#0011 (M.O.R.T.)
S.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to all
Thumbs up Re: Reducing wheel traction
We tried zip ties, but we lost too much traction and could not push other bots(2 chips + 2 drills). Then we tried another idea that some others were using in Chesapeke. Cut 4 in. lengths of the green air tubing and feed the zip ties through them, and then zip them to the tires. Works pretty good and helps get you up the step easier.
It also helps reduce traction and bounce to keep your tires slightly over inflated.
Good Luck!
Unread 26-03-2004, 21:32
edomus's Avatar
edomus edomus is offline
AKA: Evan
FLL #1218 (CHAbots)
Team Role: Driver
edomus is on a distinguished road
Send a message via AIM to edomus
at annapolis some teams were required to remove their zip ties
2004 National Finalists with 469 and 868
2004 Gallileo champions and #1 seed
  • Delphi "Driving tommarows technology" -philly 2004
  • 8th seed philly 2004
  • 58/58 at annapolis 2004 (like the improvement?)
  • Philadelphia Alliance Regional Winner!-2003
  • 7th seed Philly 2003
  • Rookie all star philly 2003
  • semi finalist Pitt 2003
  • picked 3rd in pitt 2003
  • Seeded 17(curie) at nats 2003
Unread 26-03-2004, 23:21
SkitzoSmurf's Avatar
SkitzoSmurf SkitzoSmurf is offline
Ricksta Happens
AKA: Talon
#0121 (Rhode Warriors)
SkitzoSmurf is an unknown quantity at this point
Send a message via AIM to SkitzoSmurf Send a message via Yahoo to SkitzoSmurf
Take skyway wheels, 6" I believe, drill holes in black plastic, use vaccuum hose, and zip ties, and bingo. I know that a few teams had these at the pre-season meets, and after that, EVERYONE had em.
90|>'5 ß|_|5y, ¢4|\| 1 |-|3|_¶ y0|_|?
Unread 27-03-2004, 00:31
Paradox1350's Avatar
Paradox1350 Paradox1350 is offline
FORMER Captain now Jealous Onlooker
None #1350 (Rambot)
Paradox1350 is on a distinguished road
Yeah, I reccommend the sump-pump hose. Simple, cheap, light weight, and it works. The zipties work too, but again, you could be told to remove them. That wouldn't be good.
New Hampshire BAE Regional Rookie All Star Award Winner 2004
Unread 27-03-2004, 10:18
Dan9874123's Avatar
Dan9874123 Dan9874123 is offline
FRC #0236 (Techno Ticks)
Dan9874123 can only hope to improve
Send a message via AIM to Dan9874123
you know what you do, you get a bottle of armor all and spray the wheels completely before each match. Thats what we did to our front wheels last year to reduce the traction.
"Better to remain silent and be thought a fool, than to speak out and erase all doubt"
Abraham Lincoln
Unread 28-03-2004, 19:01
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
we had this problem early on with our 6" (5" maybe?) pneumatic tires...our robot was walking as it turned so we used two pneumatic tires and two skyway wheels...
oddly enough we burn through pneumatic tires quicker this year then we did last year...and we havent damaged a skyway wheel yet...last year we were going through them every other match...
Unread 28-03-2004, 19:58
MOEmaniac's Avatar
MOEmaniac MOEmaniac is offline
The Crazy One
AKA: Steve
FRC #0365 (MOE)
MOEmaniac has a spectacular aura aboutMOEmaniac has a spectacular aura about
Send a message via AIM to MOEmaniac Send a message via Yahoo to MOEmaniac
The problem with the armor all is that it could be considered a contaminent to the field
When logic fails, force prevails!
2005 Record
Pittsburgh Regional: #1 seeded, Finalist - Thanks teams 808 and 869, Entrepreneurship Award, Sportsmanship Award, Website Award
Philly Regional: #2 seeded, Champions - Thanks teams 56 and 316, WFA Lou Rosanio, Chairmans Award
Nationals: Still to come
2004 Record
New Jersey Regional: Quarterfinalists - Thanks teams 25 and 103, Judges Award
Philly Regional: Quarterfinalists - Thanks teams 1370 and 1143, Imagery Award, Website Award, WFA Joe Perrito
Nationals: Galileo Finalists - Thanks teams 177 and 27, National Imagery Award
Unread 28-03-2004, 20:05
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
not that this could really help you right now, but in the future USE 6 WHEEL DRIVE.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 28-03-2004, 21:37
oreocookeee oreocookeee is offline
Critic Extraordinaire
AKA: orie
#0810 (Mechanical Bulls)
oreocookeee is on a distinguished road
Send a message via AIM to oreocookeee
my team has been having the same problem with turning. the solution that we came up with at the philadelpia regional was to use tie wraps covered by pneumatic tubing. we drilled holes in the sides of two of our beadlock wheels, fed the tie wraps through a few inches of tubing, and secured them by looping them around the tires and through the holes. we figured the judges wouldnt mind them as much since the tubing is smooth and wont damage the field. they allowed it, but they also told us that putting anything over the wheels will not be allowed at championships (nats; im trying to get out of the habit of saying that). it worked alright but it is just a temporary fix and we will probably consider replacing our wheels or something.
Unread 29-03-2004, 08:03
MrToast's Avatar
MrToast MrToast is offline
I named Greg Needel's cat!
AKA: Dave DeLong
no team (Rhode Warriors)
MrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud of
Send a message via AIM to MrToast
Wrap the wheels in duct tape. It's cheaper than pool hose...
(#121, 2004) Archimedes semi-finalists with 237 and 386! I had an awesome time guys, and thanks for the hat!
(#121, 2004) BC5 semi-finalists with 190 and 1027! Awesome time! We went further than I thought we could! Thanks for all your help w/ our transmission!
(#121, 2005) Galileo quarter-finalists with 47 and 203! Thanks for all your support through the stress!
If it moves and it shouldn't, use duct tape.
If it doesn't move and it should, use WD-40
"It'll all work out in the end, and if it doesn't, it's not the end." - Jeff Bullock
Clamping wheel hubs sanddrag Technical Discussion 7 29-02-2004 00:20
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
traction questions AlbertW Rules/Strategy 2 05-01-2003 17:58
Friction, traction, torque - oh my... Gui Cavalcanti Technical Discussion 30 13-08-2002 18:01
