Go to Post I like how the photo is of John Neun, and everyone is still making fun of John V-Neun - Jay Trzaskos [more]
Unread 29-03-2004, 10:32
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: You will be mine
Unread 29-03-2004, 10:38
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: pic: You will be mine
Blue Lightining's well-working, scope-bot type thing was, well, well-working...
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Ken,
I see that you got your robot all fixed up, and even a bit improved since the finals of the Pittsburgh regional. For those who weren't in Pittsburgh, 578's robot took a huge pounding in the second match of the finals. At one point as I stood in the drivers station, out of the corner of my eye I saw pieces of their tri-wheel fly up in he air. It was not a pretty scene. Kudos on the great job of getting the robot back together. It looks amazing.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 29-03-2004, 12:35
thanks - our team worked most of the day thrusday to add the plastic ball holding box in our pits
and to get our triwheels reassembled - we had to go back and use the original alum ones that our Mechanical Engineer had originally made, but decided where too heavy
we asked the inspectors if using the original alum ones were ok since we had shipped the bot with nylon ones, and they said as long as form and function were exactly the same, the different marterial was not a problem.
we had to remove a pneumatic cylinder from our platform lifter to free up weight.
Since we are not competing anymore this year I guess we can tell everyone one of our trade secrets. When we added the plastic box in the pits at Buckeye it didnt work! it would pick up one ball, but when you tried to get a second one under it the first one jammed against the back wall.
we were almost ready to take it off, but we decided to try one last thing- we sprayed the insides walls with silicon, then wiped it down really good - there was no residue left, and the silicon did not come off on the balls, but it allowed them to slide on the plastic instead of hanging and binding
so if any team has been trying to herd balls with PVC or metal arms, and getting the balls wedged and having your bot drive up on them, try putting a film of silicon spray on those surfaces - it was literally the magic that saved the day for us at Buckeye.
dont put it on so heavy that the surface stays wet - wipe it down good with a rag - it will leave a film, almost like polishing the surface, and it wont come off on the balls, so its not in violation of the rules.
Unread 29-03-2004, 13:46
Programming User
A lot of people are going to kill you for not telling earlier...
Clever solution.
pic: 294's First Inventor Robot (pic 1)... CD47-Bot Robot Showcase 4 10-03-2004 19:34
pic: Team 1053's very first ever teaser pic CD47-Bot Robot Showcase 3 16-02-2004 22:56
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
