Go to Post What's so bad about Matt? I mean, if the guy can explain PID so that even I can understand it, he can't be all that bad... - Billfred [more]
Unread 29-03-2004, 13:52
Re: 12V Power Supply Feeds My Robot
Originally Posted by MikeDubreuil
So something like the Astron RS-70M ?
Mike,
The 70 A would be OK and cheaper I think. The "M" indicates meters and you usually get a premium for those. Again, the wires you use will drop some voltage so you might want some welding cable (#2 or larger)to run from the supply to robot. Before you commit dollars, use a current meter and find out what the current draw actually is. A supply with enough current to drive the robot might easily be worth several batteries.
Where do you actually build your robot and who does the building??? Elgin Clock General Forum 47 14-11-2006 17:50
Kamikaze Robot Strategy... Joe Johnson Rules/Strategy 30 07-04-2002 21:42
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
