Go to Post I think we are having that "hard fun" that Woodie Flowers keeps talking about. - OZ_341 [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 24-03-2004, 03:19
Allison K's Avatar
Allison K Allison K is offline
AKA: Allison Kneisler
FRC #3538 (Avondale RoboJackets)
Allison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond repute
EduBot Help, RC Controller
Our team needs help getting the remote control to work. we have it set up as in the picture below, except there are three PWM cables between the reciever thing and the robot controller that I took out to make the picture clearer. What do all the rest of those wires do? Do we need a separate battery for the Reciever? Any ideas on why it's not working? Could it be something in the programming? Thanks
Allison
FRC3538 : RoboJackets : 2014-??? : Head Coach & Drive Coach
FRC226 : Hammerheads : 2003-2013 : Strategist
Unread 24-03-2004, 07:03
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: EduBot Help, RC Controller
Allison
Remote controller? What do you mean?
Unread 24-03-2004, 13:27
Allison K's Avatar
How do we make this (see pic below) send a signal to the EduBot? Is it possible?
Unread 24-03-2004, 19:55
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
ok, Let me first make sure I understand the parts your working with, it looks like a 3-channel remote control setup. yea, you can make this work, gonna take some programming, and some creativity. I'm thinking you can take the 3 pwm outputs from the receiver, and hook them into the analog imputs. your going to have to program the controlor to understand what to do with the incomming signals, like analog input 1 could be for throttle, so, when you push the control stick foward, the range increases on the edubot RI and by programming, tell the motors to increase in speed. I've never done this, but I think something like that would work. My reasoning is you have analog outputs, so put'em in the analog inputs, program it to understand the users input commands, and enjoy. I'm interested in seeing this work, I have a similar transmitter, and receiver unit around here somewhere, Maybe i'll try a similar setup and see what happens. My guess is it will work.
"Jack of all trades, master of none, though offtimes better than master of one".
Unread 25-03-2004, 15:25
CHS_Tommy's Avatar
CHS_Tommy CHS_Tommy is offline
#1368 (Perpetual motion)
Team Role: Driver
CHS_Tommy is on a distinguished road
Send a message via AIM to CHS_Tommy
from my experience in racing R/C cars, what you have is a 4 channel airplane radio with a reciever that has a built in ESC(electronic speed control), the 3 output 3 pin ports are for servos controling rudders and such and the 2 thick wires are for the main rotor. in my opinion, getting that module to link into the edubot is a big challenge and there are other options.
First- you probably want to invest about $40 in a 4-channel reciever(picture attatched) W/O all the built in ESC and such(the edu. controller does that for you)
Second- the radio you pictured looks like a air model, and the frequency crystals might be for air use only, in most states, it is illegal, although the cops arn't going to check your crystals on your gear, your conscience might nag at you...you might want to buy a set of ground, 4 channel crystals(picture attatched)
Both the reciever and the crystals can be found at www towerhobbies.com
Now, to get it running, you will need to find cables that will connect the 3 pin ports in the reciever to the R\C input ports on the edu. controller.
No power needs to be run to the reciever, but you will need to program the edu. board(far from my expertice...)
ID:	2026  Click image for larger version
Raoul got 6 years for murder. He also got $10,000 for the hit. if his common-law wife spends $100 per month, how much money will he have when he gets out?
Extra credit: how much more time will he get for killing the ho that spent his money?
Unread 29-03-2004, 16:48
InnovationFirst's Avatar
InnovationFirst InnovationFirst is offline
Official FIRST Supplier
InnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond repute
Allison,
What you have should work without any problem, and without any programming, if you follow the instructions in the EDU-2004-RC Reference Guide on our Documentation web page:
http://innovationfirst.com/FIRSTRobo...umentation.htm
Basically you should connect the three servo outputs on the bottom right corner of your receiver to the connectors labeled "R/C PWM IN" on your Mini-RC. To see what functions these inputs control by default, refer to the Mini RC 2004 Default Software Guide, also on our Documentation page.
Changing the function is a relatively simple matter of programming, which even a non-programmer can easily learn to do by following the instructions in the 2004 Programming Reference Guide.
Further information on which radio systems to use can be found in the Radio Control Selection Guide on our White Papers web page:
http://innovationfirst.com/FIRSTRobo...ite_papers.htm
It does look like you are using a model designed for use with aircraft, and to modify it to operate on the ground vehicle frequencies (as you should legally be doing) would involve sending it to the manufacturer to retune it. Once modified for ground frequency use, you would then use crystals to select the channel. Changing from air to ground frequencies is not simply a matter of swapping crystals. Your local hobby shop should be able to answer any questions you have about R/C systems.
Regards,
Innovation First, Inc.
Tether for new EduBot Controller gburlison Programming 9 18-12-2003 17:53
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
Can you use PWMs (Red or Blue) with the edubot controller? Dr.Bot Robotics Education and Curriculum 3 04-12-2003 23:51
EDUBot controller app seanwitte Robotics Education and Curriculum 0 02-11-2003 19:53
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
