Go to Post In theory, there is no difference between theory and practice. In practice, however... - Alan Anderson [more]
Unread 29-03-2004, 18:57
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Sometimes autonomous cycles at half rate (19 Hz instead of 38 Hz)
Originally Posted by KenWittlief
on thing thats really useful for debugging your code is to use the user_mode variable on the OI - you only get to see one byte of data, but its there all the time
when we used printf's in our code it would lag about 10 seconds from when the data changed in the RC - I dont know why
It shouldn't be that extreme.
Future of Autonomous Mode FadyS. Programming 41 24-05-2004 19:45
A better autonomous method.. randomperson Programming 4 24-02-2004 18:02
Flow rate / remaining pressure swabbie58 Pneumatics 5 11-02-2004 12:57
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Kill Switch UCGL_Guy Programming 8 15-01-2003 17:39
