Go to Post Nothing is perfect - but AM is a phenomenal company! - iambujo [more]
Unread 29-03-2004, 19:05
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Sometimes autonomous cycles at half rate (19 Hz instead of 38 Hz)
Originally Posted by gnormhurst
I thought of taking my scope on the plane to Atlanta, but the thought passed (Tek 475 -- about the size of another carry on, but much more fragile than my socks).
Man, I have fold memories of my old 475. Looks like they can be found on ebay pretty cheaply. You know you're a middle aged EE geek when you dream of oscilloscopes past .
Besides, I think Kevin Watson's unmodified tracker.hex code had this same behavior, too. I think, but I might not swear to it.
The tracker code is pretty efficient; I can't imagine it taking more than a millisecond to execute each pass.
-Kevin
Kevin Watson
http://kevin.org
Future of Autonomous Mode FadyS. Programming 41 24-05-2004 19:45
A better autonomous method.. randomperson Programming 4 24-02-2004 18:02
Flow rate / remaining pressure swabbie58 Pneumatics 5 11-02-2004 12:57
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Kill Switch UCGL_Guy Programming 8 15-01-2003 17:39
