Go to Post Your not a robot (and they aren't perfect either) - Conor Ryan [more]
Unread 29-03-2004, 20:55
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Offloading intterupts to a counter
I have been looking for ways to offload counting encoder clicks from the microprocessor to another chip so that i can get as high a click rate as i want (8,000+) There are thosands of dedicated counting ICs that cost only a few dollars and could easily handle the rate i want to use, but controlling them looks to be a problem when i want to have 4 encoders. I have only begun to look, but from what i have seen, counters designed for encoders have a relatively complicated scheme just for reading the counter, more than i'd like to implement in software and wire. Does your team use a counter or some other sort of electronics to reduce the number of interrupts on the RC from encoders or other sensors?
Team 1257
Counter Strike Gadget470 Chit-Chat 20 11-07-2005 14:03
Odd counter problems Catastrophy Programming 30 16-02-2004 23:41
Counter chips Ryan Meador Programming 9 15-02-2003 00:07
Microsoft Launches Counter Switch Campaign, Then Takes It Away. Joe Matt Chit-Chat 11 17-10-2002 15:53
Counter loop archiver 2001 3 24-06-2002 00:44
