Go to Post I should learn to keep my mouth shut until I actually look at the rules. - seanwitte [more]
Unread 29-03-2004, 20:07
Roland's Avatar
Roland Roland is offline
Post-A-Holic
#1466
Team Role: Webmaster
Roland is infamous around these partsRoland is infamous around these partsRoland is infamous around these parts
Autonomous weirdness in user_routines_fast.c
Until today we've been running all of our autonomous code in user_routines.c and only running it unless we have a certain combination of switces on a joystick port set. Yesterday, we made a competition port cable with the autonomous selection switch. We moved all of our auton code to the autonomous loop in u_r_f.c and tried to run our code, but it didn't send out the PWM values. It seems to be doing something, as a pneumatic valve actuates whenever we put it in autonomous mode, but nothing else seems to be doing anything. Any ideas?
Thanks,
Roland
Unread 29-03-2004, 20:49
Re: Autonomous weirdness in user_routines_fast.c
Originally Posted by Roland
...We moved all of our auton code to the autonomous loop in u_r_f.c and tried to run our code, but it didn't send out the PWM values...
The default User_Autonomous_Code function fails to call the routine to generate PWMs 13-16. If those are the ones you're using, add Generate_Pwms(pwm13,pwm14,pwm15,pwm16); right before Putdata(&txdata); and it should start working.
Unread 29-03-2004, 21:07
Roland's Avatar
Post-A-Holic
#1466
Nope, we weren't using those PWMs. We found a lot of problems like = instead of ==, though, so we seem to be getting closer to finding a solution. Our programming mentor is here now, so we're in good hands.
Unread 29-03-2004, 21:38
when you moved it to the other file, did you bring all the variable declarations with you?
Unread 30-03-2004, 00:26
10intheCrunch's Avatar
10intheCrunch 10intheCrunch is offline
Who's John V-Neun?
AKA: Alex Baxter
None #0254 (Cheesy Poofs)
10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough
Send a message via AIM to 10intheCrunch
You'd get compiletime errors if you were missing declarations...sounds like you aren't calling Putdata(), but that would show up as a Code Error I believe. Have any error lights, or error from compiletime?
~Alex Baxter
Programming, Arms operation, Team 254
Unread 30-03-2004, 00:48
Roland's Avatar
Post-A-Holic
#1466
OK, we fixed it. It seems we were trying to access some switches on the OI during autonomous mode, and that's what screwed us up. Thanks for all your help!
Unread 30-03-2004, 11:36
not necessarily - if you have variables in the other file with the same names it will compile, but if you had meant to be using the same variables your program would not run correctly.
Future of Autonomous Mode FadyS. Programming 41 24-05-2004 19:45
A better autonomous method.. randomperson Programming 4 24-02-2004 18:02
Autonomous Program Names Venkatesh Programming 12 17-02-2004 10:25
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Kill Switch UCGL_Guy Programming 8 15-01-2003 17:39
