Go to Post I would say that you are not an engineer until you've both obtained the aforementioned peice of paper AND done something with your tumescent engineers forebrain. - phrontist [more]
Unread 30-03-2004, 08:57
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
Parallel Motor Connection
Maybe a noob question, but curious.
Can we parallel a window motor with a globe motor on one speed controller? The rules say you can't use more than one globe motor on one speed controller, and say that you can use two window motors on one speed controller. So, can you use one globe motor and one window motor on one speed controller?
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Unread 30-03-2004, 09:05
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
Re: Parallel Motor Connection
not sure....
bitlate to be asking this lol...
try the rules forum maybe?
i wouldn't have thought so though....
but i could be wrong....
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 30-03-2004, 09:15
Don Wright's Avatar
FRC #0469
I know it's a bit late, but it might be an easy way to help one of our mechanisms.
Product Manager
Unread 30-03-2004, 09:25
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Do you have another speed controler? Or the weight to mount one. It's pretty easy to tie two speed controlers to the same control in software.
Unread 30-03-2004, 09:28
Don Wright's Avatar
FRC #0469
Space and weight...
Product Manager
Unread 30-03-2004, 09:54
D.J. Fluck
Posts: n/a
I wouldn't trust a response here from some random poster....id take it to the official question forum and if they say yes and you do it, you can take a copy of their response to inspection if the inspector tries to challenge that.
Unread 30-03-2004, 10:00
Don Wright's Avatar
FRC #0469
Yea...I agree. But there are several people on here who I would trust and I can get a general response to see if it's worth bothering FIRST with the question.
It's something I will have to quickly add on Thursday anyway, so if worst comes to worst, I could just ask at the competition.
Thanks.
Product Manager
Unread 30-03-2004, 10:14
AKA: Tom Cooper
Thanks.
We driving two motors each side for our drive line. A cim and a drill. each with it's own controler. So in code it's
pwm01 = pwm03 = p1_y ;
We are also using two motors, A window and a Fisher price this way for the Winch mech on our arm.
That's why I asked if you had the space and weight left , some place to put another victor and the bot is light enough that it would not put you over the 130. We are bumping the 130 with everything we do.
Unread 30-03-2004, 10:20
I took a look at the motor specs, and I'm puzzled why we can run two window motors off of a speed controller, but not two globe motors.
The window motor's free current is about 2 amps, and stall current is about 25 amps.
The globe motor's free current is about 1 amp, and stall current is about 19 amps.
I had assumed that the rule was because the globe motor was a more powerful motor and 2 could exceed the rating of the speed controller when they stalled. However, the stall current would still be less then the 40 amps rating of the speed controller and certainly less then 2 window motors.
However, since that isn't the case, I don't understand the intent of the ruling, and can't give you good advice about a window and globe motor combined. So, this is definetly something to ask FIRST.
Unread 30-03-2004, 10:43
Don,
From the Inspection Checklist revised 03/08/04...
Only 1 Drill, CIM, F-P, van door, and Globe motors on one
Innovation First speed controller, and not on Spike relays 5.2.7-R33
Only one motor per Victor 884 controllers (except two
window motors are OK) Victor cannot be an 883. 5.2.5-R09
5.2.7-R34,R35
Only 1 seat or window motor or air compressor per Spike. 5.2.7-R31, 5.2.7-R36
The numbers following each reference are the robot rules that apply.
Sorry,
Unread 30-03-2004, 11:13
Don Wright's Avatar
FRC #0469
Thanks again Al... I was afraid of that. Not trying to get away with anything, but just trying to save some hecticness (is that a word?) on Thursday by just adding a window motor would be MUCH easier than adding another speed controller, connector, wire, etc...
Product Manager
Unread 30-03-2004, 13:32
Don,
If you need any help (or any team for that matter) Please look us up in the pits. I am guessing that I will be inspecting on Thursday but usually have time for questions and suggestions.
See you there.
Unread 30-03-2004, 21:23
Don Wright's Avatar
FRC #0469
Thanks! Just trying to optimize a few things... See you in two days!
Product Manager
QBASIC, Parallel Ports, and Windows XP Venkatesh Electrical 1 21-03-2004 19:07
Working in Parallel dubya404 3D Animation and Competition 7 28-01-2003 11:48
Voltage Range of Analog Inputs Ulibrium Electrical 21 15-02-2002 14:11
