Go to Post If you want to have other teams cheer for you all day long at competition, name your team "Robot Coming Through". - Gary Dillard [more]
Unread 30-03-2004, 10:48
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
Re: syntax in c???
% is usually called the "mod" or "modulus" operator, but that means the same thing as remainder.
A couple of things to be careful of. The behavior of % with negative operands is not standardized. In
( a % b )
if a or b is negative, C only guarantees that the absolute value of the result will be less than b. Better make sure the numbers are positive. One way to do this is to add a multiple of the second operand to the first operand. But be careful of precedence.
The order of precedence of '%' is the same as for '*' and '/', which is higher than for '+' and '-'. So
( ii + 16 % 8 )
evaluates the same as
(ii + 0)
which is just
(ii)
Use parens to get what you want:
( (ii+16) % 8 )
It also makes for more readable code.
-norm
Trenton Tornadoes 381
2004 Philadelphia Regional Winners
2006 Xerox Creativity Award
My corner of the USPTO.
My favorite error message from gcc: main is usually a function
My favorite error message from Windows: There is not enough disk space available to delete this file.
BS2 syntax (PBASIC) on the new controllers? Maybe! Jeremy_Mc Programming 0 25-10-2003 15:00
PBASIC Syntax Question Raven_Writer Programming 4 20-08-2003 08:07
PBASIC language syntax WizardOfAz Programming 14 30-04-2003 10:23
Pbasic 2.5 syntax Rickertsen2 Programming 10 15-02-2003 08:56
UltraEdit Syntax Highlighting Jeff McCune Programming 9 19-01-2003 20:08
