Re: Offloading intterupts to a counter
10kHz is pushing it if each count causes an interrupt - if the internal counters are on an I/O pin then it can count at 10Mhz with a 40MHz clock on the uP
terminal count is when you preload the counter everytime it overflows - so with an 8 bit counter you can have it overflow everytime it counts to 1, or to 256 and everything in between, depending on what you set it up to preload with. |
I just spent some time looking at data sheet on the 18fxx20 chip that the RC uses. There are 5 counters that i think i can use (as long as their inputs are in fact one of the digital inputs, i think im gonna need to ask IFI about this) there are 3 that can be used as 16 bit and 2 that can only go up to 8 bit. Because i don't see anyway of counting down, the only option is two have two counter's per wheel and use an encoder enterpreter chip that can output two streams, one for up clicks and one for down clicks. This means that at best, i can have one encoder on two 16 bit counters, one on two 8 bit counters, and the other two on interrupts. I think this maybe pointless anyway because the interrupt digital I/O pins and the counter pins are most likely the same (again, i have to ask IFI).
specific chips...
I want to say right away that I am not a EE (though I sometimes play one on TV ;-).
If you want specific chips, I have found the following from Digi-key. I believe they will work, but it is possible you may need an inverter here or a NOR gate there to get things to work exactly as you want. As to the 8 bit up/down counter: SN74ALS867ADW http://focus.ti.com/lit/ds/sdas115c/sdas115c.pdf As to an 8 bit parallel load shift register: 74F676 http://www.fairchildsemi.com/ds/74/74F676.pdf You can have the clock for the counter be driven by one channel of the encoder, the other channel of the encoder is tied to the up/dn pin of the counter. The CPU drives the "parallel load" mode of the shift register and then shift in the bits to the its input pins. You can daisy chain the 676's to have the data look like one long register. You can also cascade the counters if you need to have more counts than an 8 bit number can hold. Alternatively, you can also reset the counters after you read them so that you can just accumulate the total count inside your CPU. You run the risk potential of missing a count when you reset the counters if you are not careful, but depending on your application, this may or may not be a big deal. With some clever circuitry and/or software you can avoid this problem but this is more than I want to get into here. I don't know if this helps, but it should be a good start. Joe J. P.S. I have used the 676 before so I can vouch for it with first hand knowledge. However, I have not used the 867 before -- I have always had some other 4 bit counters hanging around the office that I could cascaded into whatever size counter I needed. From what you are talking about, I suppose you will need more than 8 bits perhaps 16 bits. This gets tedious with 4 bit counters so I suggested an 8 bit version. Looking at the data sheets though I am pretty sure that it will work out for your application -- perhaps others have favorites they are used to using that they can vouch for from personal experience. Last edited by Joe Johnson : 30-03-2004 at 15:42. |
Re: specific chips...
I wrote up some code to do what i think you're saying: Code:
char encVel()
char encVel;
for(int i = 1; i<9; i++)
/*set clock to shift register high*/
shiftClkA = 1;
/*read the current bit of the shift register encVel*/
encVel |= serialInput<<i
/*set clock back*/
shiftClkA=0;
/*reset counter*/
counterResetA = 1;
counterResetA = 0;
return encVel;
| Counter Strike | Gadget470 | Chit-Chat | 20 | 11-07-2005 14:03 |
| Odd counter problems | Catastrophy | Programming | 30 | 16-02-2004 23:41 |
| Counter chips | Ryan Meador | Programming | 9 | 15-02-2003 00:07 |
| Microsoft Launches Counter Switch Campaign, Then Takes It Away. | Joe Matt | Chit-Chat | 11 | 17-10-2002 15:53 |
| Counter loop | archiver | 2001 | 3 | 24-06-2002 00:44 |
