Go to Post I don't care if students, engineers, my aging grandmother, or a pack of monkeys builds the robot...as long as at least one student walks away inspired then the goal of FIRST has been reached. - Andy Grady [more]
Unread 30-03-2004, 14:10
Re: Rigged partner assignments?
it seems like this is not a very good way to go- if you are aligned with 3 or 4 other excellent teams then your matches have a better chance of running up high scores, which affects your placement
and if you are always playing with or against very simple bots that cant score many points, you are not going to be ranked very high at the end of the qual matches
surely FIRST, with all the brainpower at its disposal, can find a way to make sure teams are not always playing in matches together all day long and ensure that enough time is allowed between matches to at least get a new battery and make any quick needed repairs.
there has to be at least ONE person in FIRST who is good at math :^)
im mean, come on now - even if you slip the teams by one match (2 minutes) that means one of the teams you played with last time will play one match before you next time, and one will play one match behind you next time - if you do that all day long you will play with different teams in every match - some are on a 40minute schedule, some are on 44, some are on 48 and some are on 52 - to make up for the difference you switch ends on saturday and move the other way.
Division assignments now available in Team 340 database archiver 2001 13 24-06-2002 03:05
about picking up your alliance partner archiver 2000 1 23-06-2002 22:34
Pit Area Assignments greenz_gurl15 Championship Event 5 20-04-2002 13:44
254 The Best Partner in FIRST sfield Regional Competitions 5 03-04-2002 23:23
