Go to Post Maybe if we get lucky [the GDC] will just say chute door. - IronicDeadBird [more]
Unread 30-03-2004, 16:10
Pattyta Pattyta is offline
Pattyta is on a distinguished road
counting in seconds for the autonomous mode??
hi there,,,
does any one knows how to convert the cycles of the autonomous mode 26.2ms to like actual seconds to keep a counter in seconds???
Thnx
Rockie team
help plz competition in 2 days
Unread 30-03-2004, 16:31
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Re: counting in seconds for the autonomous mode??
Here's some code I wrote that we never used. Basicly, you follow the table and it shows you how many ticks or loops is equal to X number of seconds. You set the timer by calling auton_timer_1_start(), pass the number of ticks (loops) it should wait. In your code you can check if the time has passed by using something like this:
if (auton_timer_1()) {
     // Time has been reached
} else {
     // Still cycling, time has not been reached
Let me know if you don't understand anything. Here's the code:
// Start prototypes
unsigned char auton_timer_1();
void auton_timer_1_start(unsigned int time);
// End Prototypes
// Variables needed
unsigned int auton_timer_1_current = 0;	// Is updated every 26.2ms loop when using timer 1
unsigned int auton_timer_1_limit = 0;	// Is the time limit, which gets set by auton_timer_1_start()
// Done with variables
/* ################################ Start Timer Table ########################
			1s/26.2ms =~ 38 ticks/s
I.E: If you want a 1 second timer, you must set the timer for 38 ticks.
		-= Seconds =-	-= Ticks =-
		0.25			10
		0.50			19
		0.75			29
		1.00			38
		1.25			48
		1.50			57
		1.75			67
		2.00			76
		2.25			86
		2.50			95
		2.75			105
		3.00			115
		3.25			124
		3.50			134
		3.75			143
		4.00			153
		4.25			162
		4.50			172
		4.75			181
		5.00			191
 ############################### End Timer Table ################ */
* FUNCTION NAME: auton_timer_1_start
* PURPOSE:       Set and start timer 1
* CALLED FROM:   anywhere
* ARGUMENTS:     time limit (unsigned int)
* RETURNS:       void
	void auton_timer_1_start(unsigned int time) {
		auton_timer_1_limit = time;
	return;
* PURPOSE:       Checks timer 1 to see if limit has been reached.
* ARGUMENTS:     none
* RETURNS:       TRUE if limit has been reached, FALSE if time has not expired
	unsigned char auton_timer_1(void) {
		++auton_timer_1_current;
		if (auton_timer_1_current >= auton_timer_1_limit) {
			return 1;
		} else {
			return 0;
Unread 30-03-2004, 16:37
Here's the simple solution I used to keep track of milliseconds.
#define MS *4
void User_Autonomous_Code(void)
	unsigned int clicks; /* 4000 clicks per second theoretical, 4007.63358779 clicks actual :-) */
	clicks = 0;
	while (autonomous_mode)   /* DO NOT CHANGE! */
		if (statusflag.NEW_SPI_DATA)      /* 26.2ms loop area */
			Getdata(&rxdata);   /* DO NOT DELETE, or you will be stuck here forever! */
			if (clicks < 16000 MS)
				clicks += 105; /* 26.2 more milliseconds have elapsed, this count will be fast by just over 0.19% */
			else
				clicks = 16000 MS; /* peg at 16 seconds */
			/* Add your own autonomous code here. */
			User_Mode_byte = clicks/400;
			Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
			Putdata(&txdata);   /* DO NOT DELETE, or you will get no PWM outputs! */
I complicated things slightly by using four "clicks" per millisecond. In the normal case of autonomous operation, the unsigned int will not overflow, but I limited it to 16 seconds anyway. Defining MS as a modifier was just a convenience so the other programmer could use "real" times while deciding when the program should take action.
The User_Mode_byte on the OI counts in tenths of a second while the autonomous function is running.
Unread 30-03-2004, 16:39
TedP TedP is offline
TedP will become famous soon enough
First: Feel Free to Re-Organize IFI's Autonomous Code
You may want to back up a little bit. Note that the only reason that loop is 26.2 ms is because of that Getdata. You only need to call Getdata when that statusflag.NEW_SPI_DATA flag gets set. Thus, if you organize your code well, you can run much faster cycles in autonomous mode. That may or may not be helpful to you.
Additionally, someone's mentioned how you should put the Generate_Pwms in autonomous mode as well before the Putdata call. You might think about replacing the whole thing with Process_Data_From_Local_IO, and now that I think about it, you should probably put that P_D_F_L_IO outside the slow if( statusflag... ) block. That way you'll be able to respond to robot sensors much more quickly in the exact same fashion as you respond to sensors in non-autonomous mode.
Don't Use the 26.2 ms Cycles to Count Time
Now, that being the case, I would not recommend using the 26.2 ms flag for timing. If you wanted to, you could count down from 38, decrementing once a cycle, and every time you hit 0 you would have gone ABOUT 1 second. But there are better ways to doing things.
Use the PIC Counters to Keep Time for You (with Interrupts)
I'm fairly sure that the student who did most of the coding for the robot found instructions on IFI's website on how to configure the counters to keep time for the robot. Right now, I can't find where he found it, but I can show you the simple example in our own code:
http://www.osufirst.org/twiki/bin/vi...04RegionalCode
You'll see that WE MUST INCLUDE timers.h. This is a SYSTEM INCLUDE, so you'll have to include it with less-than and greater-than braces rather than quotes. After this, it's fairly easy to configure a timer which produces an interrupt every 100th of a second (you can change this to faster or slower rates, but our code is configured for 100ths of a second).
Look at the interrupt handler in user_routes_fast.c. You'll see that AT THE VERY BOTTOM OF IT, it increments an elapsedTime and also sets a timeUpdate. elapsedTime is our on-board "clock." Every second, it sees an increment of 100. timeUpdate is a variable we use to communicate that a new "count" just occurred, letting some of our other routines do some "sampling." That's another story.
We also had to add code to the Initialize routine to configure the counter.
After all this, it was about 5 lines of code, and we could count on (no pun intended) elapsedTime keeping an "on-board clock" for us. I'd recommend doing something like this in your setup.
Unread 30-03-2004, 16:44
It makes sense to call Process_Data_From_Local_IO() inside the while loop but outside the if (statusflag.NEW_SPI_DATA) block. But you should not be calling Generate_Pwms() in the fast loop -- the PIC PWM outputs get a little squirrely if you write to them too quickly.
Unread 30-03-2004, 16:47
hmmmm.... I dont understand TedPs adversion to counting SW loops.
someone has tested the timing of the statusflag.NEW_SPI_DATA event- its controlled by a timer in the communications loop and testing has shown its dead accurate every time, unless you have so much code that it takes more than 26mS seconds to execute.
statusflag.NEW_SPI_DATA will be true 38 times a second - you can even round it off to 40 to make it simpler - I cant imagine anyone needing finer resolution that 1/38th of a second while setting up the sequence of events in auton mode ?
Unread 30-03-2004, 18:43
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
hi there,,,
Thnx
Rockie team
Time can be measured in seconds, or minutes, or hours, or microseconds. Why do you need to work in units of seconds? That conversion requires floating point arithmetic, and that means a lot of CPU time is used up. But how about using a new unit for time? Call it "ticks". The conversion factor for seconds to ticks is
ticks = seconds * (10e6 / 2e18 );
The autonomous period lasts 572 ticks. The entire match is 4578 ticks.
You can keep track of ticks using integers and integer math, and avoid all that floating point stuff that takes up memory and CPU time.
BTW, I programmed my auton to take a swipe at the trigger ball starting at 534 ticks (38 ticks before the end of auton). It knocked off the ball, but the blue balls were not released. They claimed it was too late. It was our last match and the first time everything came together for IR tracking (i.e. we didn't get rammed) Hmmm.... At nationals I'm gonna back that down to 80 ticks before the end of auton.
Trenton Tornadoes 381
2004 Philadelphia Regional Winners
2006 Xerox Creativity Award
My corner of the USPTO.
My favorite error message from gcc: main is usually a function
My favorite error message from Windows: There is not enough disk space available to delete this file.
Unread 30-03-2004, 22:23
when should we stop the robot, using a counter by following the line ????
is there any way of figuring that out/??? or is the only way just trying it on the robot and hoping it works ???
Unread 30-03-2004, 23:26
gnormhurst's Avatar
Norm Hurst
AKA: gnorm
Here's a very similar thread that may help you.
-norm
Unread 30-03-2004, 23:29
Carpe diem
I tried to help you all I could. Now I'm at a loss trying to understand you. Please use complete sentances and proper punctuation. I spent about 10 minutes preparing an answer, please spend more than 1 minute answering.
Unread 31-03-2004, 00:16
Sorry for that.. Thanks for your help. its just that i am really stressed about this and i feel i can't handle it anymore
ok here i go again
i think i have the code working for the line following with two sensors.
is there any way of knowing when to stop other than just timing it with like a stopwatch? to avoid the robot to hit the wall and be stuck to it ?
Unread 31-03-2004, 00:25
Carpe diem
ok here i go again
There's 2 ways you can detect the end of travel:
1. Your time and stop watch idea.
2. You could install a microswitch (digital switch) and a bumper to the front of your robot. If you were following the line, and the bumper sensing switch was closed, you would know you hit the wall.
Unread 31-03-2004, 00:41
the competition is this thursday so i think we'll have to do the stopwatch measure.
thnx people
Unread 31-03-2004, 02:00
For one, there's no reason your autonomous mode code has to run at the slow rate. Only Getdata() when that flag goes high, and otherwise rattle around as fast as you can. You can Generate_Pwms() as fast as you can as well because those are the FAST PWMs. They can be handled specially. Additionally, Putdata() can be called as fast as you'd like. IFI specifically says that there is no harm done by calling Putdata() too fast; it also says that there's not necessarily anything gained. It's in the documentation.
Having interrupt-controlled timing that is triggered by an interrupt generated by the terminal count of a hardware timer timed fairly precisely to go off every 100th of a second (or even finer) seems much simpler than using a counter to do this timing. Additionally, you can use this counter later on in your competition mode code.
It just seems much cleaner to have an interrupt manage all your timing for you. You can get fairly fine time resolution, and you don't have to worry about making sure you increment in time. Run code as slow as you'd like; the interrupt will jump in when it needs to increment your "clock."
If you do things the more naive way, then you gain a second every twenty seconds, and you lose the ability to differentiate in time among a great number of cycles of your code. That may not be that big of a deal, but it definitely could use some improvement. Using the simple interrupt-driven timing does this. That's all I'm saying.
Unread 31-03-2004, 02:08
See page 18 of:
http://www.innovationfirst.com/FIRST...10-29-2003.pdf
on IFI's website. In particular, you see that PutData() will handle PWMs 1-12, (slow PWMs) and those can only be changed every 26ms. While 13-16 are the fast PWMs that can be changed more often (every 2 ms).
IFI's website is very clear that PutData and Generate_Pwms(13-16) can be called as quickly as possible, but G_Pwms is the only thing that generates those PWMs that quickly. It warns that devices connected to the PWM outputs may have trouble with the fast changing PWM outputs and to check those device specifications, but there's nothing about the RC that makes this a bad idea.
After all, aren't Putdata and Generate_Pwms called in the default fast routines anyway?
Future of Autonomous Mode FadyS. Programming 41 24-05-2004 19:45
Simple Autonomous Mode Example deltacoder1020 Programming 5 08-03-2004 20:22
Initializing autonomous mode Mr. Lim Programming 7 02-02-2004 07:26
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
autonomous mode timer Don Programming 6 09-02-2003 22:16
