Go to Post [how to read the rules] Slowly, carefully, word by word, taking your time as if it was the last corndog of the summer. - Foster [more]
Unread 30-03-2004, 17:31
Joel J's Avatar
Joel J Joel J is offline
do you..
Re: Despite what IFI says, you can configure autonomous from OI...
I've heard talk of doing this both last year and this year; however, didn't IFI release a firmware update that did away with our ability to retain the last value sent from the OI? There was something mentioned about it in one of the team updates. They may have changed some other aspect of the control system, but maybe we should check first, eh?
If IFI's firmware update did make this method impossible, then the only option left would be to not perform the upgrade on the controller, if you have yet to do so.
Joel Johnson
RAGE (173) Alumni, 1999-2003
A better autonomous method.. randomperson Programming 4 24-02-2004 18:02
IFI Loader Problems BrendaB Programming 3 24-01-2004 22:45
variable? manodrum Programming 11 01-04-2003 17:20
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Kill Switch UCGL_Guy Programming 8 15-01-2003 17:39
