Go to Post FIRST isn't about money or robots... it is about people. Take care of that and the rest will follow. - dtengineering [more]
Unread 30-03-2004, 18:26
omega's Avatar
omega omega is offline
omega is an unknown quantity at this point
timer
i need a quick refresh on timers for c/c++
i can remeber for vb but i also have the visual agp to help and i dont have that for c/c++ or c-bot
Unread 30-03-2004, 18:32
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: timer
Are you speaking about in general (I.E. on a computer) or on the PIC?
Either way it will be totally different than VB.
Unread 30-03-2004, 18:40
omega's Avatar
Re: timer
i know that
mostly low proxy but ill to re-learn it in genereal anyways
Unread 30-03-2004, 18:52
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
Re: timer
IFI Whitepaper ("Using Polled or Interrupt-driven Timers"). Check it out.
Timer interrupt hic-cupping - HELP roknjohn Programming 9 15-03-2004 17:56
Interrupt timer, executing code asap? SeanCassidy Programming 10 07-03-2004 01:47
Problems with interrupt timer actorindp Programming 1 20-02-2004 16:59
Countdown timer untill ship date??!? M. Hicken General Forum 16 20-02-2004 11:38
autonomous mode timer Don Programming 6 09-02-2003 22:16
