Go to Post I never wanted to be a teacher. This was the year I learned that I am one. It turns out mentors are teachers. Oops. - marshall [more]
Unread 31-03-2004, 00:49
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
trentonDrive.c: our joystick/wheel drive code
I thought I'd share this bit of code. This is a single-joystick control routine for a robot chassis that uses two-wheel, two-motor drive. This is the version we are using in competition.
Its features include:
Squaring the motor values (not the joystick axes). This desensitizes
the joystick and compensates for the non-linear speed vs.
voltage function of the drill motors.
Turning radius independent of speed. The X Axis sets the ratio of the
wheel speeds, not the difference.
Y axis dead band independent of Victor deadband. Victor
deadband bypassed in software. No x axis deadband.
Dynamic rounding for an extra 2 bits of resolution for better slow-speed
control.
No floating point math.
I have been very pleased with how this code performs. It probably won't work on your machine without some modification (e.g. my motors are on pwm10 and pwm11) -- your mileage may vary. But since so many robots use two-wheel drive, it might be useful to many people.
Zipped code is attached.
#include "trentonDrive.h"
int clipInt( int in, int lowLimit, int highLimit );
#define RUN_MOTORS 1
// global joystick calibration values.
unsigned char xMax = 254;
unsigned char xMin =   0;
unsigned char xMid = 127, yMid = 127;
unsigned char xHalfRange = 128;
#define ROUNDING_BITS 2
#define ROUNDING_CYCLES ( 1 << ROUNDING_BITS )
#define HALF_DEAD_BAND 3
#define CENTER_VALUE 127
#define LEFT_MOTOR  pwm11
#define RIGHT_MOTOR pwm10
#define SIGN( x )  ( ((x) > 0 ) ? +1 : -1 )
#define ABS( x )  ( ((x) > 0 ) ? (x) : (-x) )
* FUNCTION NAME: trentonDrive
* PURPOSE:       Interfaces one joystick to the motors for manual driving.
* X & Y axes are linear here; the *wheel* values are squared.
* I think the motors' speed vs. voltage curve flattens out at high speed,
* so squaring the motors tends to make it more linear.  Part of the problem
* of control at high speeds is that making a small change to the motor
* voltage doesn't make much difference when the curve has a low slope.  Squaring
* the motors helps this.
* CALLED FROM:   this file, Default_routine
* ARGUMENTS:     xAxis, yAxis: joystick values in.
*                leftWheel, rightWheel: PWM values out
* RETURNS:       nothing
void
trentonDrive( unsigned char xAxis, unsigned char yAxis )
  int tmp;
  static unsigned char fracCycle = 0;  // for dynamic rounding
  unsigned char xx, yy;
  char signX, signY;
  long innerWheel, outerWheel;
  long left, right; // wheels
  unsigned char xMid = 127;
  unsigned char yMid = 127;
  // break the x & y axes into absolute value and sign.
  tmp = ( (int) xAxis ) - xMid;
  signX = SIGN( tmp );
  xx    = ABS ( tmp );
  tmp = ( (int) yAxis ) - yMid;
  signY = SIGN( tmp );
  yy    = ABS ( tmp );
  // give the y axis a deadband so the motors
  // will stop when you let go!
  if ( yy < HALF_DEAD_BAND )
    signY = 0;
  // The main feature of this routine is that
  // for a given x axis position, the ratio of the
  // wheel speeds is independent of the y axis.  This
  // means that the turning radius won't change as you
  // change the speed of a turn.
  // The outer wheel goes faster in a turn.
  // When the X axis is all the way left, the left
  // wheel will stop and the robot will turn on the
  // left wheel at a speed determined by the y axis.
  // The same goes for the right.
  // these have a range as big as 2^7
  outerWheel = (xHalfRange + (long)(xx)) * yy / xHalfRange;
  innerWheel = (xHalfRange - (long)(xx)) * yy / xHalfRange;
  // square the wheel values
  // This compensates for the non-linear speed/voltage
  // relationship of the motors.
  // The range will be (2^7 * 2^7) = 2^14
  outerWheel *= outerWheel;
  innerWheel *= innerWheel;
  // re-range it, 2^14 to 2^9
  // the "+ 16" is like adding 0.5 before rounding.
  outerWheel = ( outerWheel + 16 ) >> 5;
  innerWheel = ( innerWheel + 16 ) >> 5;
  // apply sign of Y axis to both wheels
  outerWheel *= signY;
  innerWheel *= signY;
  // Use sign of x axis to determine if left
  // or right wheel is the outer wheel of the turn.
  if ( signX > 0 )
    left  = (int) outerWheel;
    right = (int) innerWheel;
  else
    right = (int) outerWheel;
    left  = (int) innerWheel;
  // The Victor speed controllers have a deadband of about +/- 7 that
  // we will now bypass.  We are still at the *4 range, so we use 4*7=28.
  if ( left < 0 )
      left -= 28;
  else if ( left > 0 )
      left += 28;
  if ( right < 0 )
      right -= 28;
  else if ( right > 0 )
      right += 28;
  // dynamic rounding dither
  fracCycle++;
  if ( fracCycle >= ROUNDING_CYCLES )
    fracCycle = 0;
  // add 0,1,2,3,0,1,2,3,...
  // this dynamic rounding hopes to achieve an extra 2 bits of
  // control granularity
  left  = (left  + fracCycle ) / 4;  // must use division, not right shift,
  right = (right + fracCycle ) / 4;  // because these are signed values.
  // limit the range and send it out
  RIGHT_MOTOR  = (unsigned char) clipInt( left,  -127, 127 ) + CENTER_VALUE;
  LEFT_MOTOR   = (unsigned char) clipInt( right, -127, 127 ) + CENTER_VALUE;
#if RUN_MOTORS == 0
  LEFT_MOTOR   = CENTER_VALUE;
  RIGHT_MOTOR  = CENTER_VALUE;
#endif
  if ( in > highLimit )
    return highLimit;
  else if ( in < lowLimit )
    return lowLimit;
  else
    return in;
Trenton Tornadoes 381
2004 Philadelphia Regional Winners
2006 Xerox Creativity Award
My corner of the USPTO.
My favorite error message from gcc: main is usually a function
My favorite error message from Windows: There is not enough disk space available to delete this file.
What is wrong with this code???? It won't Compile and I don't know why? Please Help CrashZero Programming 23 26-03-2004 09:44
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
TechnoKats Automated Test Drive Code Greg McCoy Programming 1 16-01-2003 17:45
