Go to Post The toughest part about that Chairman's Award was the fact that someone was cutting onions in the stands near 558/on the field while it was being read out. At least that was the excuse I'm going to use ;) - esquared [more]
Unread 31-03-2004, 13:17
supergrover supergrover is offline
AKA: Chris Warren
FRC #1397 (Ajax Rams)
supergrover is an unknown quantity at this point
Exclamation Distance between IR sensors?
We used the code from kevin.org (navigate) and we can't find what the distance should be between the two IR sensors. We want to use this for our autonamous mode, but we don't know how to make it work.
Unread 31-03-2004, 15:52
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
Re: Distance between IR sensors?
Originally Posted by supergrover
We used the code from kevin.org (navigate) and we can't find what the distance should be between the two IR sensors. We want to use this for our autonomous mode, but we don't know how to make it work.
First, Kevin's approach uses four sensors -- two on each of two "trackers" that are hobby servos. Here are some pictures of how Kevin built his.
We mounted our two trackers on each side of our robot, about as far apart as we could (28-30"). Think of this: If you want to estimate the distance to the beacon, you can use the difference in the tracker pointing direction of the two trackers. But if the trackers are close together, that difference will be very small.
Kevin has a good FAQ about some of the problems people have run into.
Let me guess: you've got a regional starting tomorrow and you want to build a tracking system tonight? I wish you luck. It took us weeks to get a workable IR system, and that included access to our robot.
If you really want to do something autonomously, look at some of the simple state machine postings in this forum, and create a dead reckoning system of timed runs and turns. That's what most people are doing, anyway. If you don't have an IR system you will have plenty of company!
-norm
Trenton Tornadoes 381
2004 Philadelphia Regional Winners
2006 Xerox Creativity Award
My corner of the USPTO.
My favorite error message from gcc: main is usually a function
My favorite error message from Windows: There is not enough disk space available to delete this file.
Optical Sensors Used as Encoders? uvabrad825 Technical Discussion 22 03-05-2004 13:22
Getting Fancy with Sensors FadyS. Programming 30 10-03-2004 15:02
Why not analog sensors?? gnormhurst Programming 16 07-03-2004 16:14
Interrupts and rotation sensors kor Programming 3 12-02-2004 11:05
optimum sensing distance for sensors DaveG702 Electrical 3 31-01-2003 22:06
