Go to Post Sleep?! How am I supposed to do that with the build season done?! There are still practice bots to make! - [more]
Unread 01-04-2004, 16:25
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Inertial Navigation and Robot Turning
Its my understanding that an inertial navigation systems basically use two accellerometers to judge the robots realative position by integrating twice. What I don't understand is how the system deals with turning. If the robot turns, all further readings would be off. Is another sensor (compass?) required? Am I missing something obvious?
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 01-04-2004, 17:12
Re: Inertial Navigation and Robot Turning
conventional inertail navigation systems used gyroscopes on gimbal bearings that allowed the system to determine how far it has turned on each axis
you can now get solid state yaw rate sensors that put out a signal proportional to the rate at which its being turned on one axis - if you wanted to make a 3D system you would use 3 of them
search the forum for 'yaw rate' sensor or 'gyro' - there lots of threads already - more than I could type out in a hour - that explain where to get them and how to use them
but in essence - their output is in degrees/second - so by simply accumulating the output (repeatedly adding it to a large variable) you end up with degrees - compass heading. the ADXRS150EB (or something like that) is the most common one to use - you can get em for $50
Unread 01-04-2004, 22:14
phrontist's Avatar
Proto-Engineer
<mr. burns>Excellent...</mr. burns>
autonomous IR Navigation CharlieWilken Programming 4 02-03-2004 11:59
Expert advice needed!!! punarhero Technical Discussion 16 01-03-2004 11:34
What to do with autonomous Rickertsen2 Programming 48 17-02-2004 16:22
Inertial navigation systems Greg Needel Technical Discussion 21 02-02-2004 02:54
Inertial Navigation System CyberWolf_22 Electrical 19 04-12-2003 17:27
