Go to Post I’m not decently dressed for this picture.......I have no FIRST shirt, FIRST hat or FIRST pin anywhere on me! - Rich Wong [more]
Unread 31-03-2004, 17:07
rmeenaks's Avatar
rmeenaks rmeenaks is offline
AKA: Ram Meenakshisundaram
no team (Hauppauge Eagles)
rmeenaks is on a distinguished road
Talking ADXRS300EB Rate Gyro
Hi,
I am now the proud owner of an ADXRS300EB and I want to hook this beauty up to the lego mindstorms sensor port. I already own the following interface connector:
http://www.techno-stuff.com/3wire.htm
so I think it should be pretty easy. I was thinking about connecting it following way:
AGND to Ground
AVCC to +5V
Rate Out to Signal
would this cause any problems? The interface produces about 6mA which should? be enough to drive the sensor. Am I correct? I dont want to damage the sensor since it is a bit expensive...
Any help is much appreciated. I really need to get this going, but I am not too electronic savy
Cheers,
Ram
Unread 31-03-2004, 17:11
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: ADXRS300EB Rate Gyro
please dont double post the same thread in more then one spot.
-Michael Dessingue
Unread 31-03-2004, 17:26
rmeenaks's Avatar
Sorry, this is my first time on this Forum
Ram
Unread 31-03-2004, 20:44
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
It's alright that you double posted, as a newer member to the forum, I think people will understand that you where just unsure which area was the correct place to post, and you just wanted to get the info, no harm, no foul. Mike, loosen up a bit will you.
Also, the way your planning on wiring it sounds right, I mean it makes sense.
power to power, ground to ground, data to data.
The more and more I see what you can do with lego mindstorms, the more and more I want to go out and buy a kit, and a bunch of parts and just let loose.
"Jack of all trades, master of none, though offtimes better than master of one".
Unread 01-04-2004, 10:25
rmeenaks's Avatar
Thanks. I wasnt sure which forum to post it until I found the electrical forum. It seems that I can hook it up like this as well:
1) Connect +5V to pin 1 (AVCC)
2) Connect signal to pin 2 (RATEOUT)
3) Connect ground to pin 8 (AGND)
4) Connect +5 to pin 13 (PDD)
5) Connect ground to pin 12 (PGND)
I found this out which I did a search through the forums
Should of done that first. Now the quesion is is 6mA enough (or too much) to drive the sensor???
Cheers ,
Ram
Unread 01-04-2004, 10:34
From the data sheet:
POWER SUPPLY             min typ  max
Operating Voltage Range 4.75 5.00 5.25 V
Quiescent Supply Current      6.0 8.0 mA
Unread 01-04-2004, 11:25
it cant be too much- the sensor will only draw what it needs - sounds like it should work - let us know what you end up doing with this - I think I have a mindstorm set lying around in the basement somewhere
Unread 01-04-2004, 11:31
rmeenaks's Avatar
Hi,
Cool! Now off to my bench to get this thing working
I have lots of uses for this as I currently have an accelerometer as well (ADXL202E) hooked up to the mindstorms. I am planning on creating a two-wheeled balancing robot similar to LegWay, but with the ADXRS300/ADXL202 and a bit of Kalman filtering. This is just a proof-of-concept design to see if this combo works. This should be a very interesting project. This leaves me with more room to add yet another sensor to the mixture (like the Sharp distance sensor or a light sensor). I let you guys know when I finish this...
Thanks for all the help,
Ram
Unread 01-04-2004, 16:45
Hi,
Ram
Hey Ram , good luck it seems Joe and Ken have set you on the right path, keep us updated on your pojects and if you have any other questions, were here to help. Also what mindstorms kit are you using this on, i havent seemed to find a good mindstorms kit that i could use to test rotational and yaw rate sensors on?
-Michael Dessingue
Unread 01-04-2004, 17:45
rmeenaks's Avatar
All the mindstorm kits (the RCX that is) are pretty much the same. They have versions 1.0 (which has an AC adapter + Batteries), RCX 1.5 (removed the AC adapter plug ), and RCX 2.0 (updated firmware and USB-based but similar to 1.5). All are compatible with each other. I have both a 1.5 and a 1.0. I am testing this on a 1.0-based RCX brick. I will definitely let you guys know how this goes. Thanks for all the help. I am really glad I found this site. A lot of cool and interesting stuff here....
Cheers,
Ram
Unread 02-04-2004, 09:52
Cheers,
Ram
You should try out the Hauppauge FIRST Robotics club too.
We do this "cool and interesting stuff."
Unread 02-04-2004, 10:41
rmeenaks's Avatar
Hi,
Dont know what the age group the Hauppauge FIRST targets, but I am over 30
So, can I still join....
Cheers,
Ram
PS: Saw the FIRST contest at Brentwood. Was cheering my local team all the way....
Unread 02-04-2004, 11:46
Hi,
I'm WAY over 30 and they don't hold it against me!
Your experiments will inspire the students.
Unread 02-04-2004, 12:25
rmeenaks's Avatar
Hmmm, when do you guys meet? I live just across the street from Hauppauge High in the apartment complexes (Windsor)....
Cheers,
Ram
Unread 02-04-2004, 12:54
Cheers,
Ram
During the FIRST season (January - April) just about every day 6pm to 10pm.
School is out for spring break after today though and we'll be at Nationals the week after.
If you're willing I'll set up a meeting where I can introduce some of the other adult mentors and you can see the robot when it returns from Nationals.
We can talk a little shop. The team has an ADXRS150EB in use on the robot and I have a 300 at home. I'm Comp Sci, so code is my primary interest, but we have mechanical and electrical mentors as well. We have also started a Mindstorm league in the Middle School.
Use my email to talk more: Mark.McLeod@ngc.com
ADXRS150 gyro yaw rate sensor Brian M. Electrical 13 17-10-2004 02:28
ADXRS300EB Rate Gyro rmeenaks Technical Discussion 0 31-03-2004 16:48
Wierd gyro code problems...pls help Salik Syed Programming 4 14-03-2004 01:29
gyro code odin892 Programming 2 08-04-2003 14:50
Yaw rate sensor (gyro for the layperson) Kris Verdeyen Rules/Strategy 4 14-01-2002 00:41
