Go to Post Don'tcha love technology? :p - Cory [more]
Unread 03-04-2004, 01:32
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Re: Soundproofing
Cheap easy things I have seen.
Place matress against walls.
Hang sheets from ceiling to floor in front of matress, makes the room look better and deadens sound some.
Hang a blanket from the ceiling like an upside down rug.
Mount noise making equipment - drums, speakers, jumping guitarists - on folded blankets or other 'squishy' material. This prevents sound from travling along the floor joists.
Sound is a wave, and moves best through a solid. It dosn't like to move from soild to air and back to solid. So when you have the drum on some plywood floating on a few thick blankets, the sound dosn't travel around your house nearly as much.
Read about the properties of sound in a physic book and you will prolly come up with some more ideas.
Wetzel
Unread 03-04-2004, 06:38
ZACH P. ZACH P. is offline
Insert Custom User Title
#0321 (Robolancers)
ZACH P. is on a distinguished road
Send a message via AIM to ZACH P.
Re: Soundproofing
instead of buying those acoustic tiels and such, use egg cartons. the shape of the little "cones" is actually excellent for keeping sound in. You can use those on the ceiling, and then hang very heavy drapes on the walls and such.
pi is exactly 3
IM me at: zmstr265
Unread 03-04-2004, 10:16
Re: Soundproofing
Filter out what has already been printed here. The only way to contain sound is add mass between the source and everything else. The amount you want to spend and the area in which you work are the determining factors. If you want to play drums while everyone in your house sleeps, you are going to have to spend some money. If you just want to practice while everyone else is watching TV that will cost you less. Several books are availabe at the library, I recommend F. Alton Everest and his books on studio design.
You are dealing with two types of sound transmission. One is through the air and the other is structure borne. To kill the first, you need a lot of mass, double or triple drywall walls and ceiling, lead sheeting, sand filled block, concrete, etc. The second requires you to break the structure to eleiminate the path between what's inside and what's outside. The only way to do that is to build a room within a room. You start by floating a floor (isolators, rubber sheeting etc.) then build the walls and ceiling on the floating the floor. This is what most studios do. Everywhere that the structures must meet, there needs to be a flexible joint.
For a simple practice room in a basement, build the walls on the concrete floor but not touching any of the building. Use 2x6 studs on 16" centers for rigidity. Add a ceiling to the walls that does not touch the building. Two sheets of 1/2 - 5/8" drywall inside the room (walls and ceiling) and one sheet of drywall outside the room. Caulk the joints with the floor with butyl rubber so there is no air leaks. Do this for each layer and overlap drywall so there is no common joint. You can add insulation to the walls but it adds little to the transmission loss. (remember mass is what kills the transmission so even rigid fiberglass is only a pound or two per square foot compard to the weight of drywall.) Add a heavy, solid core door with rubber seals around the sides and top and a drop seal at the threshold. Any intrusion (air conditioning, electrical) must be sealed (caulk) and isolated as well. Make the duct a nice long run with a few bends, fully lined with fiberglass, so that no sounds travels out through the duct. Wide, short duct is better than square cross sections or round.
If you do the work yourself, you maybe looking at $500-$1000 in materials. Add absoption (foam, carpet, heavy drape) as you feel you need, to make the room comfortable to be in.
Unread 03-04-2004, 14:51
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Re: Soundproofing
You might want to check out http://www.soundproofing.org/infopages/myths.htm.
It turns out that egg cartons aren't that good after all.
Zan Hecht
Unread 03-04-2004, 17:18
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Soundproofing
At the little studio in school they have moving blankets on the walls. I don't think they've ever done anything loud in there so I couldn't tell you how well it works. But its an idea.
Unread 04-04-2004, 00:20
#0321 (Robolancers)
Re: Soundproofing
Hmm, this means my lair wasn't soundproof at all! All my secret plans!
pi is exactly 3
IM me at: zmstr265
