Go to Post Come on baby, do the logomotion with me. - JaneYoung [more]
View Poll Results: Do you use Ternary Operators in your code?
Yes 17 60.71%
No 11 39.29%
Voters: 28. You may not vote on this poll
Unread 02-04-2004, 22:48
NotQuiteFree's Avatar
NotQuiteFree NotQuiteFree is offline
Do the WAAAAVE!!
#0957 (Watson)
NotQuiteFree will become famous soon enough
Send a message via MSN to NotQuiteFree
Do you use ternary operators in your code?
Did anyone use Ternary operators in their code this year? Personally, I find them a little bit...odd. I figure using an if-then statement that says:
if(y > 5)
x = 1;
is easier to read and understand, than:
x = ((y > 5) ? 1 : 0);
But, that is just one man's opinion. What do you all think?
For some more info on Ternary Operators, Binary Operators, and Unary Operators, see
http://cplus.about.com/library/gloss...ryoperator.htm
(This is where I got the example)
Yo.
Unread 02-04-2004, 23:28
10intheCrunch's Avatar
10intheCrunch 10intheCrunch is offline
Who's John V-Neun?
AKA: Alex Baxter
None #0254 (Cheesy Poofs)
10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough
Send a message via AIM to 10intheCrunch
Re: Do you use ternary operators in your code?
I really do like ternary operators, for a variety of reasons. First, I do find it easier to read in some circumstances (and it looks kinda cool), but more importantly, its useful for the macros that we use in our code. One example:
#define GetVal(leftVal, rightVal) autoSide ? leftVal : rightVal
This lets us program our autonomous modes for each side into one program. The values are different (obviously) for each side, and this saves us from having to have two entire functions for left/right (important when you are running out of space). While you can write this code into a seperate function, it's more useful as the macro (as function calls take up a considerable amount of space too).
We also use ternary ops in our Min, Max and Min/Max macros. Very handy.
A warning though: ternary operators themselves take up a lot of space in assembly, even though it's only one line of code (this makes sense). Using them too frequently can quickly run you out of space (try and use it once to set a value instead of everywhere because it's easy to write).
One weird thing that we noticed when tight on space: when the ternary op was in a function, it took up more space than when it was in a macro, but moving other small function calls (that didn't include ternarys) were actually *much* larger when in a macro. Check the map and proceed with caution.
~Alex Baxter
Programming, Arms operation, Team 254
Unread 03-04-2004, 07:55
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
if(y > 5)
x = 1;
Just as a warning, those aren't completely equilivant. For them to be the same, you should do:
if(y > 5)
    x = 1;
else
    x = 0;
Or:
x = 0;
if(y > 5)
    x = 1;
Just pointing that out.
Personally, I think that the extra else clause is worth it in terms of readablitiy. When I'm reading other's code, I find it hard to spot terenary operators, as they are on one line and it is only noted by a : and a ?.
Unread 04-04-2004, 21:22
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Maybe it's just the fact that I like functional programming much more than imperative, but I find myself using ?: all over the place, especially within arguments to function calls. For example, here's a line out of RoboEmu:
GetMenu()->CheckMenuItem(IDM_AUTO, (COSSpecific::autoMode ? MF_CHECKED : MF_UNCHECKED));
-Rob
Unread 04-04-2004, 21:51
piotrm's Avatar
piotrm piotrm is offline
AKA: Piotr Mardziel
FRC #0190 (Gompei and the HERD)
piotrm has a spectacular aura aboutpiotrm has a spectacular aura about
Send a message via AIM to piotrm
note: I do not do any robot programming so I assume "your code" here means just any code at all.
Things begin looking even more usefull with things like this:
(c ? a : b) = d;
I didn't really use this operator much until I had to learn scheme for school once. Afterwards I was really annoyed that some things are much easier to do in functional programming but are harder in languages like C. As suggested by rbayer, this operator gives one a slight taste of a functional programming in some cases.
Unread 04-04-2004, 22:39
JJG13's Avatar
JJG13 JJG13 is offline
Yoda
AKA: Joshua Graffman
None #0180 (SPAM)
JJG13 has a spectacular aura aboutJJG13 has a spectacular aura aboutJJG13 has a spectacular aura about
I try to do whatever is most readable but instead of
if (y > 5)
  x = 1;
else
  x = 0;
I would use
x = (y > 5);
Behold the power of SPAM.
Unread 05-04-2004, 00:13
wun's Avatar
wun wun is offline
AKA: David Wolever
#0865 (Warp7)
wun will become famous soon enough
Send a message via AIM to wun Send a message via MSN to wun
I also perfer to use x = (y > 5);
it just seems like such a waste to type
if (y > 5){
x =1;
} else {
x = 0;
Help Microsoft stop piracy. Use Linux!
I have three gmail invitations, message me if you want one
Unread 05-04-2004, 00:44
Who's John V-Neun?
AKA: Alex Baxter
Not to mention inefficient with respect to program space.
~Alex Baxter
Unread 05-04-2004, 19:41
pickle's Avatar
pickle pickle is offline
Talking vegtable
AKA: Jeremy
#1296 (Full Metal Jackets)
pickle is on a distinguished road
Send a message via AIM to pickle
I use them all the time, just becuase I think it looks cool
Well,I use them for assignment more than anything because I think its more readable that way and simpler to type (in my eyes at least)
2004 Rookie Inspiration Award winner - Midwest Regional
2004 Autodesk Visualization Award winner - Lone Star Regional
2004 Quarterfinalist - Lone Star Regional
2005 Team Spirit Award - Lone Star Regional
Unread 06-04-2004, 13:28
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Me too. I ussually write them as (A? B : D) because that makes sense to me.
Unread 06-04-2004, 20:52
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
if (y > 5)
  x = 1;
else
  x = 0;
I would use
x = (y > 5);
yes, just remember that not all compilers treat logical TRUE as 1. it's fine to use it as long as you know it works. more robust, however, is the ternary:
x = y > 5 ? 1 : 0;
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 06-04-2004, 22:00
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
If you're worried about speed, consider that some compilers may give faster code for one idiom over another. Once, I was working on the inner loop of a 2-D image filtering program, so there were four nested loops, which gave width x height x filterWidth x filterHeight loops per image frame, or over 3 million iterations for a 720x480 image and a 3x3 filter -- so I spent some time tweaking it for speed.
I was surprised to learn that this
  h = ( FW2 - xt );
  h = ( x+h  < 0 ) ?     -x : h;
  h = ( x+h >= PW )? PW-x-1 : h;
was slower than this
  h = ( FW2 - xt );
  if ( x+h < 0 )
    h = -x;
  else if ( x+h >= PW )
    h = PW-x-1;
Perhaps it was faster because it only took one branch at a time, whereas the ternary method always executed both expressions. Or maybe it was faster because the compiler wasn't very good. These days speed isn't often an issue, and I haven't come close to the 26.2 ms budget. But when speed is an issue, consider this.
Trenton Tornadoes 381
2004 Philadelphia Regional Winners
2006 Xerox Creativity Award
My corner of the USPTO.
My favorite error message from gcc: main is usually a function
My favorite error message from Windows: There is not enough disk space available to delete this file.
Unread 06-04-2004, 22:04
AKA: Jamie Bliss
It was probably the else that did it. But good point.
One of our mentors does AMX programming for a local TV group. Aparently, else ifs slow it WAY down.
Besides, Ternaries are probably compiled into Ifs.
Unread 06-04-2004, 22:32
Anthony Kesich's Avatar
Anthony Kesich Anthony Kesich is offline
Programmer Turned Engineer
AKA: SonKenshin
#1097 (Site 3 Engineernig)
Anthony Kesich has a spectacular aura aboutAnthony Kesich has a spectacular aura about
Send a message via AIM to Anthony Kesich
I like them because one of our animators also knows some programming so he likes to go into my code and try to change it. So whenever I can, I use Ternaries because they look very cryptic, thereby enhancing my feeling as a programmer and confusing the bejezus out of the animator who eventually gives up because he claims his head is going to explode. hehehe...
-Kesich
C is screwing up my English--I'm ending all my sentences in semi-colons;
Horray for most things! -George Carlin
"Sure, I'll play rugby. Besides, I have a lot of experience running from really big guys who want to cream me." -Me, Freshman year
Unread 07-04-2004, 11:21
AKA: Jamie Bliss
That's out of a Dilbert, isn't it?
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
Interrupt timer, executing code asap? SeanCassidy Programming 10 07-03-2004 01:47
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
