Intermittant control with radio
Sympton: When using the radio to move the robot around we experience intermittant motor activity; cuts off and on but not in a consistent pattern. Very erratic and causes the robot move in a very herky-jerky motion and is nearly useless.
These symptons do NOT appear under autonomous mode or when tethered; motor runs very strong. So, I have two questions. First, anyone else ever experience this? Second, any ideas what may cause this? Thanks! |
Re: Intermittant control with radio
One question, did this happen at a compitition while on the playing field?
EDIT: *points to below post* dez beat me 2 it |
replace the cables that connect your radio from the RC and also radio to the oi, sometimes they can get damaged from constant use and also see if there might be any visible damage to the oi, rc or radios.
Yep, it was during the Houston Regionals. I'll have to check which radio was on the robot; we did experience the problem with two different radios. But, that still doesn't mean the wrong one was on the bot.
Talk about a frustrating day! Sean |
Innovation FIRST representatives monitor radio signals. They are also very helpful in fixing problems like these. You may want to have one of the reps stop by your pits at nationals if you are unable to determine the problem. MY experiences with them have been very positive.
#7
if this happened somewhere besides an event I would say that someone else is using your frequency - one thing to keep an eye on is the radio link LED on the OI
if it keeps turning red, you are losing your link - either someone else is on the same channel, or something is wrong with your transmitters (could be at the OI or on the bot, either one) |
#8
This happened to our team during the first qualification match at the Canadian regional. It's too bad too 'cause we would have won the round easily: it was two vs one, and both of our robots were disabled from the getgo. Our alliances had an untested autonomous which gave them a code error (probably an infinite loop) so they were immobile for the round. And we had that radio problem. To the best of my recollection, the "receiving" light would blink for a few seconds, then cut out for a few seconds. It was very aggravating; couldn't really do anything.
We tested everything before the match, and the radio worked fine in the practice area setup in the pits. But when both of our robots got on the field, BOTH of us seemed to have the same radio error lights come up. I don't know if our alliance partner would have had the same error while driving around though 'cause of that code error. We took the robot back to the practice area after the loss, had the same problem, and the Innovation FIRST guy couldn't figure it out. I think we just tightened our connections and then it was working fine. What cheeses me off the most though is that when both of our robots were having the same error lights when we were setting up on the field, the FIRST employees tried to fix things... they had us setup our tether (for some reason beyond me) and we both still had the same radio error lights coming up and they decided to start the match anyways when it seemed as though it was a FIRST error. I understand there's a schedule to keep to, but it hardly seems fair to me that teams should suffer because of a silly problem like the radio transmissions. If I remember, Simbotics had a radio error too and they were going to start the match anyways, but then their field mentor ran out and was adament about delaying the match until they fixed it (which they did) Good for you! Of course... we all know it's hard try and make the competition fair... just easier to remember the bad luck you get than the good luck ![]() |
#9
if they fixed the problem by tightning the connections ON YOUR BOT then it wasnt a FIRST problem, it was loose connections inside your bot
you cannot hold up a match if something is wrong with YOUR BOT - there are no timeouts in the qualification rounds. |
#10
If your robot will boot and run at all, then you can escape code error problems very easily. Simply hit the reset button on your OI after autonomous has ended, and your robot will start back up without the auto mode bit set and you'll be able to run as normal. I know Chief Delphi had that problem in their last elimination round at SVR and didn't get reset until about 20 seconds left, and it was painful to see such a good robot go down because of a very fixable problem.
#12
After setting up the controls for our second match we noticed that the No Data/Radio red LED was flickering on and off. So as Blair was doing his introductions, I ran over to the Innovation First rep to report the problem. He supplied us with a temporary radio, and the problem was solved. My advice to any teams who notice these types of radio problems is to go straight to Innovation First. Their staff is extremely knowledgable and helpful. They will go to great lengths to solve your problem. Also, make sure you check all of your connections. Many teams at the Canadian Regional reported radio problems, which ended up to be caused by loose connections. (Our team included) |
#13
We had this problem last year and a bit again this year. Then we wisened up. Theres three things:
A) Keep the radio away from any motors. They create interferiance (yes, I know I can't spell). B) If you have a shell or a cage of some sort made out of metal, put the reciever outside that (the metal in the frame will create a ferridite cage thereby weakening or blocking most electormagnetic waves). C) Make sure the two antennae (the transmitter and the reciever) are parallel. If they are perpendicualr, it harms the quality of reception. -Kesich P.S. And it did hurt when chief del phi didnt reset. We (1097, 114, and 47) could have won that match and probably made it to the finals. But you know what, it was still fun and it was just a simple mistake. No hard feelings. |
| PID control loops - closed loop feedback | KenWittlief | Technical Discussion | 56 | 26-04-2004 21:27 |
| What do you wish you knew about the new control system? | Joe Ross | Control System | 2 | 09-01-2004 21:47 |
| reworking radio control for joysticks | ajlapp | Electrical | 5 | 05-12-2003 17:38 |
| Need a FIRST Robotics control system | kershawrobotics | General Forum | 3 | 07-07-2003 09:49 |
| more control options | smokescreen | Technical Discussion | 17 | 05-03-2002 15:41 |
