Go to Post When you build a practice robot, you're literally buying time. - sanddrag [more]
Unread 03-04-2004, 22:19
Matt_Kaplan1902's Avatar
Matt_Kaplan1902 Matt_Kaplan1902 is offline
#DecadeofDelicious
FRC #1902 (Exploding Bacon)
Matt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond repute
Send a message via AIM to Matt_Kaplan1902
Chain Drive Question
I'm trying to find out if we have our chain tensioned so it doesnt hang down would that make the chain stronger and less likely to break?
Team 1902: 2007-??, Mentor
Team 108: 2002-2005, Student
Unread 03-04-2004, 22:23
computhief263's Avatar
computhief263 computhief263 is offline
Battlecry...Here We Come!
AKA: "The Freshman"
#0263 (sachem aftershock)
Team Role: Operator
computhief263 is on a distinguished road
Send a message via ICQ to computhief263 Send a message via AIM to computhief263 Send a message via MSN to computhief263 Send a message via Yahoo to computhief263
Re: Chain Drive Question
I dont know about stronger, but definatly less likely to come off the sprocket. Just be carefull to make sure the sprockets are inline w/ each other.
Tom "40Watt" Bigelow
Team Electrical/Court Jester
Proud creator of The dongle that nuked the OI, Dj in a bag, and THPD(strobe lights, a hat, a modified flashlight bulb, and a 12v B&D Firestorm™ flashlight make a good combo!)
Unread 03-04-2004, 22:30
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
It wouldnt cause the chains physical strength to increase, but more likely keep if from slipping off the sprocket. If your chain is too loose, you could try removing a full link, and replacing it with a half link, if its really loose, take out enough chain to fix the problem, you could just add a tension device, but this adds weight, and removing chains takes away weight . Generally speaking, you dont want your chain so tight that it puts alot of pressure on the axles, Try getting the chain as short as possible without trying to stretch the chain. Chain will stretch after you run it for a while, so most of the time after say the regional event is over, you can remove a half link or so to keep the chain tensioned.
"Jack of all trades, master of none, though offtimes better than master of one".
Unread 03-04-2004, 22:31
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
Better tensioned chain will have less backlash when you are switching from driving forward to driving backwards. Wether its tensioned or untensioned you will get similar moments on the chain and run the same risk of snaping the chain in either case. Preventing the chain from hanging down is not something I'd suggest doing and as Tom said, it makes it easier for the chain to come off your sprockets. The precission you need in lining up sprockets also varries for different chain sizes as does the chains strength.
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 03-04-2004, 23:21
kacz100 kacz100 is offline
Battle Cattle!
#1466 (Webb Robotics)
kacz100 is on a distinguished road
Send a message via AIM to kacz100 Send a message via Yahoo to kacz100
Just some friendly advice (for next time) go find the formula that will tell you the center to center distance of the sprockets so that the chain fits and no tensioner is needed
Kacz
Team #40 Alumni 1999 - 2002
Team #885 College Student/Mentor 2003
Team #1466 College Student/Mentor 2004
Unread 03-04-2004, 23:38
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
You might also want to make sure your sprockets are in line with eachother, so your chain isnt being bent. this will cause the chain to strecth further. Keep in mind that chains are one of the times where my "measure once, cut twice and claim the mistake was a lightening hole" philosophy doesnt work.
Unread 04-04-2004, 01:03
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
One more note. If you do tension the chain, make sure to tension is properly. If the tensioner is spring loaded, you're fine. if it's not, make sure you don't tighten it too much. The chain should really have a small amount of slack in it at rest anyways. if you over tighten/tension the chain, it will start binding and wearing the rollers and sprockets too quickly.
Unread 04-04-2004, 13:52
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Team 258 made the mistake Kevin just described this weekend, and after tensioning it quite a bit, they sheared their drive shaft in half.
The only thing I like about the 80/20 we use is the ability to slide our wheels to compensate for chain slackness.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 04-04-2004, 14:25
coreyjon's Avatar
Flight Engineer
last year we used 80/20, it was pretty nice, made it easy to tension the chains, and attach things like motor mounts and the such, We didn't use it this year, instead we went with 1x3 Al box channel, Hopefully next year the team will use 80/20, It looks good, and works well. What more could you ask for (except maybe for a cheaper price tag).
Unread 04-04-2004, 14:34
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Cory
Heh. Actually, we made some stupider mistakes than that. The tention on the chain was fine, but the output shafts from our drive gearboxes were cantilevered out into the open. Words of wisdom: never do this. Another problem we had was that the shaft was pinned off-center. If we hadn't had these other problems, we would have been fine.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 04-04-2004, 19:19
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Originally Posted by coreyjon
last year we used 80/20, it was pretty nice...
80/20 worked well for us, also.
Just to be different, the advantage of tensioners is that they make the streching of the chain much less of a problem.
Unread 04-04-2004, 20:08
BillyGoats BillyGoats is offline
Paper Eater
None #0061 (Intimidators)
BillyGoats can only hope to improve
Send a message via AIM to BillyGoats
we have always used chain and never used a chain tensioner. This year we did not have one drive train problem... usually we have a chain fall off or something once. This year we used 1inch shafts (we kept bending the 1/2 inch shafts) we also used spacer on the shaft so that they can not walk off. below are some pictures.
This is an ok picture of our left side the drills and you can see the spacers.
http://www.valleytech.k12.ma.us/robo...lectronics.JPG
Just another alright shot of the drive system.
http://www.valleytech.k12.ma.us/robo...004_211Bot.JPG
Cant find any others but feel free to take a look.
http://www.valleytech.k12.ma.us/robo...photos2004.htm
or
http://www.valleytech.k12.ma.us/robo...CFRegional.htm
Keep It Simple - Team 61's Motto
Any Thing on out Robot Can be Fixed in 5 Mins!
2005 Motorola Quality Award
2004 Battle Cry 5 @ WPI Eighth Finalists...4th Seed! 6-3 Record! Thx 237 & 830!
2004 Mayhem on the Merrimack Champions! 4th Seed! 9-2 Record! Thx 562 & 1289!
2004 Mayhem on the Merrimack Fastest Robot Award!
2004 Beantown Blitz Champions! 4th Seed! 11-1 Record! Thx 571 & 1100!
2004 National Semi Finalists
2004 Florida Regional Judges Award
2004 Florida Regional Champions! Thx 945 & 386!
Unread 05-04-2004, 18:42
maclaren maclaren is offline
AKA: Dexter
FRC #0997 (Spartan Robotics)
maclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of light
ALWAYS TENSION CHAINS!!!!!!!!!!!!!!!
The reason is that you will have better efficency, better durability, better drive train response and an overall better drive system.
I'm partial to tensioning mechanisms beacuse chains will loosen over time. An adjustible tensioner WILL save you time. Adjusting a tensioner is far faster then changing the length of a chain.
There are several guidelines when using chain.
1. Lubricate!! chain will always need lubrication especialy chain sizes of #35 and smaller since they don't have rollers in them. IE built in bearings because of their size.
2. Proper alignment! is crucial for long lasting and efficent chain implementation. Any misalignment is bad engineering practice.
3. Tension chains! loose chains snap and whip under varying loads which is exactly how they are run in FIRST. Plus they last longer when properly tensioned. Properly being the keyword. The addition of an adjutible tensioner is the ideal tensioning solution in the perspective of tensioning not necisarily from the perspective of weight.
4. Design chain for short spans long spans are hard to tension properly and will put unecssary strain on chains.
5. Proper axial support. NEVER, NEVER, NEVER EVER cantilever any axle if you can posibly help it always double bearing whenever possible place a bearing on each side of any force applied. In other cases beef up axle size, and place additional bear on the other side of the already existing bearing, and shorten axle length to reduce shear force.
FOLLOW GOOD ENGINEERING PRACTICES and every component will realize it's full potential and perform to the best of it's ability giving you the best robot possible.
Unread 05-04-2004, 19:36
Grommit Grommit is offline
#0115 (Monta Vista Robotics)
Grommit will become famous soon enoughGrommit will become famous soon enough
Send a message via AIM to Grommit
We have been using chain drives for about 7 years and until this year have not ever used a tensioner. For drive shafts, we would just have someone pull as hard as possible on the wheel while tensioning it. This has never caused any problems for our drive shafts, chains or wheels, but we have a colorful history of chains coming off because they were loose.
This year we used a tensioner, not spring loaded, just a plastic adjustible runner, on our drive system, on the chain that allows it to swerve. The reason was not to protect the chain or make it easily tensioned. The real reason was that it was impossible, with our tiny sprockets, to get the wheels all aligned without tensioners.
Unread 05-04-2004, 20:37
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
[speaking as a previous MVRT member]
You need to make sure people know that instead of an actual tensioning device, we had slotted wheel mounts. To make the chains "taught" we loosened the wheel mounting bolts, slid the wheel back until the chain was taught, and tightened the wheel mounting bolts. Before we made that nifty modification, in 98 and 99 we used teflon blocks that were slid under the runs of chain and held in by screws/velcro. Both ways seemed to work just fine.
[speaking as a current mentor]
The past 2 years on 968 we used slotted wheel mounts... which worked fine (simply because we used a bosch type frame) which enabled us to easily slide the wheel mounts on the slotted chassis material with t-nuts.
This year, we chose to weld the frame (to reduce weight) and decided to come up with a tensioning device. Strangely, we came up with something similar to 115, and used HDPE rollers of various sizes. When the chain initially stretches, we simply install a larger diameter roller and the chain is tight again. (this way isnt as elegant is I would have liked, but it was about as simple and as lightweight as we could think of at the time)
Note: All of these examples are #25 chain. #35 chain is much more forgiving and sometimes does not require tensioning.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
XP Hard Drive Space Question Raven_Writer Chit-Chat 13 07-08-2003 16:38
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
question about one joystick drive programing james700 Programming 13 29-01-2003 14:49
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
