Go to Post IRI: where egos go to die...uhm..I mean fly! - Koko Ed [more]
Unread 03-04-2004, 22:13
TimeOut's Avatar
TimeOut TimeOut is offline
AKA: Sean Kelly
FRC #0499 (The Toltechs)
TimeOut is on a distinguished road
Intermittant control with radio
Sympton: When using the radio to move the robot around we experience intermittant motor activity; cuts off and on but not in a consistent pattern. Very erratic and causes the robot move in a very herky-jerky motion and is nearly useless.
These symptons do NOT appear under autonomous mode or when tethered; motor runs very strong.
So, I have two questions. First, anyone else ever experience this? Second, any ideas what may cause this?
Thanks!
Unread 03-04-2004, 22:16
computhief263's Avatar
computhief263 computhief263 is offline
Battlecry...Here We Come!
AKA: "The Freshman"
#0263 (sachem aftershock)
Team Role: Operator
computhief263 is on a distinguished road
Send a message via ICQ to computhief263 Send a message via AIM to computhief263 Send a message via MSN to computhief263 Send a message via Yahoo to computhief263
Re: Intermittant control with radio
One question, did this happen at a compitition while on the playing field?
EDIT: *points to below post* dez beat me 2 it
Tom "40Watt" Bigelow
Team Electrical/Court Jester
Proud creator of The dongle that nuked the OI, Dj in a bag, and THPD(strobe lights, a hat, a modified flashlight bulb, and a 12v B&D Firestorm™ flashlight make a good combo!)
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
replace the cables that connect your radio from the RC and also radio to the oi, sometimes they can get damaged from constant use and also see if there might be any visible damage to the oi, rc or radios.
-Michael Dessingue
Unread 03-04-2004, 22:17
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
Thanks!
My team experienced this at competition. If this is not your first year as a team, then make sure that the radio transmitter and receiver you are using are from THIS YEAR. We accidentally had last year's transmitter hooked up, which cost us a lot. This year's radios should have blue text on them.
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
Unread 03-04-2004, 22:24
TimeOut's Avatar
AKA: Sean Kelly
Yep, it was during the Houston Regionals. I'll have to check which radio was on the robot; we did experience the problem with two different radios. But, that still doesn't mean the wrong one was on the bot.
Talk about a frustrating day!
Sean
Unread 03-04-2004, 22:30
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
Innovation FIRST representatives monitor radio signals. They are also very helpful in fixing problems like these. You may want to have one of the reps stop by your pits at nationals if you are unable to determine the problem. MY experiences with them have been very positive.
Unread 03-04-2004, 23:43
if this happened somewhere besides an event I would say that someone else is using your frequency - one thing to keep an eye on is the radio link LED on the OI
if it keeps turning red, you are losing your link - either someone else is on the same channel, or something is wrong with your transmitters (could be at the OI or on the bot, either one)
Unread 04-04-2004, 14:37
FizMan's Avatar
FizMan FizMan is offline
aboot, eh?
AKA: Chris Sinclair
#0783 (Mobotics)
FizMan will become famous soon enough
Send a message via AIM to FizMan Send a message via MSN to FizMan
This happened to our team during the first qualification match at the Canadian regional. It's too bad too 'cause we would have won the round easily: it was two vs one, and both of our robots were disabled from the getgo. Our alliances had an untested autonomous which gave them a code error (probably an infinite loop) so they were immobile for the round. And we had that radio problem. To the best of my recollection, the "receiving" light would blink for a few seconds, then cut out for a few seconds. It was very aggravating; couldn't really do anything.
We tested everything before the match, and the radio worked fine in the practice area setup in the pits. But when both of our robots got on the field, BOTH of us seemed to have the same radio error lights come up. I don't know if our alliance partner would have had the same error while driving around though 'cause of that code error. We took the robot back to the practice area after the loss, had the same problem, and the Innovation FIRST guy couldn't figure it out. I think we just tightened our connections and then it was working fine.
What cheeses me off the most though is that when both of our robots were having the same error lights when we were setting up on the field, the FIRST employees tried to fix things... they had us setup our tether (for some reason beyond me) and we both still had the same radio error lights coming up and they decided to start the match anyways when it seemed as though it was a FIRST error. I understand there's a schedule to keep to, but it hardly seems fair to me that teams should suffer because of a silly problem like the radio transmissions. If I remember, Simbotics had a radio error too and they were going to start the match anyways, but then their field mentor ran out and was adament about delaying the match until they fixed it (which they did) Good for you!
Of course... we all know it's hard try and make the competition fair... just easier to remember the bad luck you get than the good luck
Unread 04-04-2004, 14:45
if they fixed the problem by tightning the connections ON YOUR BOT then it wasnt a FIRST problem, it was loose connections inside your bot
you cannot hold up a match if something is wrong with YOUR BOT - there are no timeouts in the qualification rounds.
Unread 04-04-2004, 17:50
Joshua May's Avatar
Go Bears!
This happened to our team as well. We ran a simple autonomous that was programmed about 10 minutes before our match, and we only tested that the autonomous worked. However, in the switch from autonomous to controlled, a loop or something kept us from driver control so the robot just sat there. It was an agonizing two minutes because I knew that I was the acuse of the problem with the faulty code, and my drivers just sat there trying everything to get it to work. To add insult to injury, the match was replayed because of a problem with the field, so I had to watch this happen twice.
Unread 04-04-2004, 20:17
10intheCrunch's Avatar
10intheCrunch 10intheCrunch is offline
Who's John V-Neun?
AKA: Alex Baxter
None #0254 (Cheesy Poofs)
10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough
Send a message via AIM to 10intheCrunch
If your robot will boot and run at all, then you can escape code error problems very easily. Simply hit the reset button on your OI after autonomous has ended, and your robot will start back up without the auto mode bit set and you'll be able to run as normal. I know Chief Delphi had that problem in their last elimination round at SVR and didn't get reset until about 20 seconds left, and it was painful to see such a good robot go down because of a very fixable problem.
~Alex Baxter
Programming, Arms operation, Team 254
Unread 04-04-2004, 20:48
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
We had a few radio problems on Friday of the Canadian Regional. During our first match of the day, on three separate occasions we lost communication with the robot. Luckily, we only lost the connection for a few seconds and were still able to cap and hang.
After setting up the controls for our second match we noticed that the No Data/Radio red LED was flickering on and off. So as Blair was doing his introductions, I ran over to the Innovation First rep to report the problem. He supplied us with a temporary radio, and the problem was solved.
My advice to any teams who notice these types of radio problems is to go straight to Innovation First. Their staff is extremely knowledgable and helpful. They will go to great lengths to solve your problem. Also, make sure you check all of your connections. Many teams at the Canadian Regional reported radio problems, which ended up to be caused by loose connections. (Our team included)
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 04-04-2004, 21:07
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
The Innovation First rep. was incredibly useful not only with our robot on the field, but with troubleshooting our (now-defunct) IR guidance system. Back in Pittsburgh he was checking the beacons every time our team was up, and was gving us info on telemetry he was getting to help us out after many of the matches. As usual, he was very helpful at the Canadian Regional as well. And yeah, we got our radio cable knocked out because someone forgot to use the thumbscrews. Good thing we won that match anyway.
Unread 04-04-2004, 21:22
Joshua May's Avatar
Go Bears!
That would have been good to know, thank's for the information.
Unread 04-04-2004, 21:35
Anthony Kesich's Avatar
Anthony Kesich Anthony Kesich is offline
Programmer Turned Engineer
AKA: SonKenshin
#1097 (Site 3 Engineernig)
Anthony Kesich has a spectacular aura aboutAnthony Kesich has a spectacular aura about
Send a message via AIM to Anthony Kesich
Exclamation Re: Intermittant control with radio
We had this problem last year and a bit again this year. Then we wisened up. Theres three things:
A) Keep the radio away from any motors. They create interferiance (yes, I know I can't spell).
B) If you have a shell or a cage of some sort made out of metal, put the reciever outside that (the metal in the frame will create a ferridite cage thereby weakening or blocking most electormagnetic waves).
C) Make sure the two antennae (the transmitter and the reciever) are parallel. If they are perpendicualr, it harms the quality of reception.
-Kesich
P.S. And it did hurt when chief del phi didnt reset. We (1097, 114, and 47) could have won that match and probably made it to the finals. But you know what, it was still fun and it was just a simple mistake. No hard feelings.
C is screwing up my English--I'm ending all my sentences in semi-colons;
Horray for most things! -George Carlin
"Sure, I'll play rugby. Besides, I have a lot of experience running from really big guys who want to cream me." -Me, Freshman year
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
What do you wish you knew about the new control system? Joe Ross Control System 2 09-01-2004 21:47
reworking radio control for joysticks ajlapp Electrical 5 05-12-2003 17:38
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
more control options smokescreen Technical Discussion 17 05-03-2002 15:41
