Re: Going over 6 inch step with 12 inch wheels
We had the same issue, with more mass in the rear to counter the Big ball when on the arm. Our bot can best be described as looking like a Bobcat. Arm piviots at the rear. The only way up (and we never did it in a match) is to extend the arm after the front wheels are on the platform, shifting some mass to the front tires. Then it climbed very smooth. BTW we are using the 3" tires on the kit wheels which makes a 14" wheel when all is done. This is a tire and tube that comes from Skyway.
| wheels, wheels, wheels.... | Jesse | Control System | 1 | 05-02-2004 15:00 |
| What do you use for wheels? | Andrew | Technical Discussion | 36 | 08-01-2004 10:20 |
| Lots of Wheels and F = u x N | archiver | 2001 | 17 | 23-06-2002 23:37 |
| Good or bad: back wheels coming off the ground | Gui Cavalcanti | Technical Discussion | 2 | 17-03-2002 22:09 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
