Go to Post Kyle from team 45 said "Dude, I still have 2 years left in FIRST ahahaha.." My response to that was... "Kyle, I have till the day I die." - Arefin Bari [more]
Unread 05-02-2004, 13:24
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: 716 Dual Motor/Dual Speed
Unread 05-02-2004, 13:28
JulieB's Avatar
JulieB JulieB is offline
well........
AKA: Just Julie!
FRC #0538
JulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of light
Send a message via MSN to JulieB
Re: pic: 716 Dual Motor/Dual Speed
Wow NICE!
Joel Glidden's Avatar
Joel Glidden Joel Glidden is offline
My heart pumps diesel.
FRC #4293 (Komodo)
Joel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of light
Nice work! Compact and attractive. It looks like all of your parts are do-able on manual machines. I'd be interested in seeing some more detail in the shifting mechanism. I'd also like to know what your reduction ratios are. I'd love to get my hands on your CAD drawings / models for future competitions. Thanks for the great photo.
-Joel
Unread 05-02-2004, 14:42
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
looks good! it looks similar to what we are trying for this year and kind of like Kokomo's from last year, but also different and (i hope) improved upon. good work!
Collin Fultz
Unread 05-02-2004, 15:57
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Joel: I modeled 716's shifting tranny, with the exception of the drill motor and it's gears. It is in Inventor, and if you'd like a copy, I'll send you one once I get home from school.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 05-02-2004, 16:32
Brant Bowen Brant Bowen is offline
no team (AndyMark, Inc.)
Brant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant future
Send a message via AIM to Brant Bowen
Oh yes, very nice indeed. I like how both the motors are on the same side of the gearbox, that should save a lot of space on the robot. If you don't mind, I was wondering about how much that assembly weighs?
Operations Manager - AndyMark Inc.
Co-Volunteer Coordinator - Boilermaker Regional, Crossroads Regional, Indiana Robotics Invitational
Unread 05-02-2004, 17:14
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Assuming I am understanding things correctly, I like the shifting yolk and I also like the tri-lobe drive blocks.
Can I ask a question? How much "back lash" do you have in your shifter? What I mean is how much angular rotation does can your last gear make with the output shaft held fixed and the shifter engaged?
I am curious because your design seems to have only a small amount and Andy (and others) have advocated having quite a lot so that the "dogs" have more room to engage.
But, generally speaking. Well done.
Joe J.
P.S. I am guessing that it weighs just under 4 lbs each without the motors.
Unread 07-02-2004, 01:36
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Very nice indeed. Looks similar to 116's gearbox, except yours is a bit more compact. How does the shifter work, it is unclear in the picture. Your mount for the drill motor is nice, looks pretty sturdy.
See you in DC!
Unread 07-02-2004, 01:43
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Another great design, Andy Brockway. On that shaft that is riding in 3/8" ID flanged bearings, is there a third small gear that is hidden in that picture?
Unread 07-02-2004, 01:45
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
peronsally I'm counting 10 seperate gears, but I could be wrong, I do have really bad eyesight when im not wearing my glasses!
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
Unread 07-02-2004, 02:04
Cory's Avatar
AKA: Cory McBride
that silver square piece with the chamfered corners does the same thing as the Technokat's "dog", but it does it without requiring CNC machining
. Basically, the final 2 gears you see are rotating freely around the shaft, since they have bearings pressed into them. What happens is when that square piece is moved in one direction, or the other, it engages the gear by going into a square hole on them. Since the silver square is fixed onto the shaft, when it engages the gear, it causes that one to also be "fixed" and allow it to transfer power to the output shaft, rather than spinning freely on the shaft.
Cory
2001-2004: Team 100
Unread 07-02-2004, 02:27
tkwetzel's Avatar
Good Luck Teams!
AKA: Tyler Wetzel
That's an interesting way of shifting. 116's gearbox has a gear specially made with a dog on it (use the lathe to cut down gear stock), but instead of a free spinning gear, the gear moves to engage other gears. Team 116's gearbox can be made without the use of a CNC, and this one looks the same way.
See you in DC!
Unread 05-04-2004, 16:29
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
Have you checked out 223's transmission, it is similar in the free-spinning gears on a shaft, but instead of a sliding key, they have ball bearings which pop up from inside the shaft to engage the gear.
How are you moving the shifter?
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 05-04-2004, 19:39
tkwetzel's Avatar
Good Luck Teams!
AKA: Tyler Wetzel
That would be team 222 that has that transmission. I agree that it is very sweet.
See you in DC!
Unread 05-04-2004, 22:51
sburro's Avatar
sburro sburro is offline
AKA: Joe
FRC #0663 (crusaders)
sburro will become famous soon enoughsburro will become famous soon enough
Send a message via AIM to sburro
I have a question. When two motors are used, are both motors powered at the same time? If not is this good for the Victors since now the second motor is acting like a generator?
pic: 2 speed shifty on the fly Lego Bot CD47-Bot Robot Showcase 9 31-01-2005 04:21
pic: dual speed gearbox CD47-Bot Extra Discussion 9 07-10-2003 15:04
pic: 716 single speed CD47-Bot Extra Discussion 2 09-09-2003 15:51
Multi Speed Dual Motor Gearbox tenfour General Forum 14 08-09-2003 13:09
