| View Poll Results: You Make The Call | |||
| I warn/penalize BLUE team for pinning |
19 | 36.54% |
| I award Bluabot 50 points for hanging |
31 | 59.62% |
| I award Redabot 50 points for hanging |
6 | 11.54% |
| I do not award Bluabot any points for hanging |
9 | 17.31% |
| I do not award Redabot any points for hanging |
26 | 50.00% |
| I do something else ... please explain |
4 | 7.69% |
| Multiple Choice Poll. Voters: 52. You may not vote on this poll | |||
YMTC: Bluabot sits on Redabot
You Make The Call (YMTC) is a series of situations where you can play ref and make a call. YMTC situations are not meant to represent situations that have occurred at competitions.
A special thanks to Joe for this situation. This one might be a stumper. In the third game of the finals, Bluabot and Redabot go directly for the bar. For the first time in history, two robots hang in autonomous mode! After 15 seconds, Bluabot is 6 FEET off the ground and Redabot is about 6 INCHES off the ground. With one minute remaining and the blue alliance trailing by a score of 80 to 115, Bluabot lowers itself onto Redabot forcing one of Redabot's wheels to touch the ground. Redabot does everything it can to free itself from a "Sitting Bluabot" but have no luck. The match ends with Bluabot sitting on Redabot and Redabot's wheel touching the ground. If you remove Bluabot, then Redabot will be hanging. Likewise, if you remove Redabot, Bluabot will be hanging Not counting the Bluabot and Redabot, the score is BLUE 45 and RED 85. YOU MAKE THE CALL! Do you ... (please note that you can choose multiple options with this YMTC) Please base your ruling on the 2004 rules. If you find a specific rule that addresses this situation, please share it with everyone. |
Re: YMTC: Bluabot sits on Redabot
Ok I have a question about this ! Blue bot sat itself on Red Bot during the match or after.
Ah yes this is a stumper! If this was intentional (like Blue bot just decides to drop them themselves to prevent red bot to get up) I would throw a few flags for aggressive action If Blue bot gently lowered itself (a slow decent [i've seen some robots make a decent as soon as the match is up]) then I see no real issue and Blue would be counted as hanging and red bot would be counted as touching the floor gets nothing. I'm tired and typing in te dark right now :-) and in no shape to turn the light on to search for a rule about this so someone with a lil bit more energy then I please find the rule and post. This seems like a better problem that will get much discussion |
Here's how I see it, there are three rules that need to be looked at.
1. A Blue robot can be touching a non-scoring Red robot and still get points. 2. The blue robot would still be hanging if everything else is removed therefore it is hanging. If Blue would not be hanging when Red was removed then it would not be considered hanging. 3. FIRST has said it is legal to "de-hang" another robot which is what Blue did to Red. They were hanging and Blue forced them to the platform. |
I'm not sure if this one is a stumper as much as it is unpleasant to score by the rules of the game.
Bluabot is hanging because it is not touching the ground, it would remain hanging with Redabot removed (not supported by Redabot), and it would not remain hanging (off the ground) with the horizontal bar removed. The rules as is only apply to pinning while on the carpet, so strictly speaking, pinning penalties do not apply. And if it is modified to apply on any field ground (platform and carpet), it would depend on whether Redabot could have moved away, including if Redabot was able to lower itself off the bar and drive away. If so, no penalties on Bluabot, as Redabot's movement was not inhibited. However, if Redabot cannot lower itself or move reasonably in any direction whatsoever, warnings and penalties on Bluabot, the number of penalties as per precedence on the pinning rule. Last edited by Winged Globe : 05-04-2004 at 04:44. |
if the blue bot is keeping the red bot from pulling itself up, it MUST be supporting some of its weight on the red bot, it could not possible be preventing the red bot from ascending if most of its weight were not supported by it
and the red is clearly supported by its wheels so neither are entirely supported by the bar neither are hanging BTW - this would be easy to determine - bluebots cables or hook arm would be loose on the bar, or slack, it its applying force to the redbot Last edited by KenWittlief : 05-04-2004 at 08:15. |
According to the rules, Bluabot IS hanging, and Redabot is not. However, I would penalize Bluabot for pinning. Also, Bluabot is technically not pinning, while they are inhibiting the movement of Redabot, Rule <G27> clearly states,
the red bot is not 'pinned' if it is free to drive away
the blue bot is preventing it from going up - it is blocking its path in the Z direction but its not necessarily pinning it so it cant move at all. besides, the rules state pining only applies when: Quote:
also from the rules: Quote:
#8
I asked this very question at UTC New England. The ruling was that if the Bluabot was removed and the Redabot was hanging then Redabot scores. Aidan was the Head Ref.
#9
Regarding the pinning rule, not only does it explicitly apply only to the carpet, but it is specifically designed to stop powerful robots from having too much of an advantage over weak ones (or else it would lead to some pretty defensive strategies). It's also a carry-over from old games and therefore it's reasonable to say it isn't designed to take hanging into account. FIRST has also said otherwise.
That certainly doesn't seem to be the intent of the rule. |
#11
Are you asking me, or the people that wrote the rules? The carpet clause is explicit and not open to interpretation, but furthermore, I'd do it given the chance, and I can justify it in my own mind by saying I'm preventing that robot from reaching a specific goal, rather than parking in front of them in order to take them out of the game, which is the reason the rule exists in the first place. Stopping a robot from a specific target is still GP and is strategic; pinning them for the whole match is lame (though running down 10 seconds is certainly viable).
#12
this (in a way) happened to us in Arizona. we went to hang against 190. our partner 696 was already on the bar. we needed the hang to win and stay #1 seed. 190 was up and as we went to pull up they put an arm into us and restricted our movement (up or down) (kind of pinning us) i'm not sure if it was ten seconds or less or more...but i didn't consider it pinning. luckily for us, when power was cut their motor-driven arm that was holding us lost it's power...but our nu-matic telescoping system was still trying to pressurize itself and we wound up hanging and winning. had we of not hung...i would have blamed ourself because we tried to hang in a bad spot. 190 would have had a good gameplan to keep us off the bar and would have been the better team because of this on-the-fly game plan.
anywho---i voted for no points for the bottom robot...however, if the bottom robot were removed and the top bot hung (it would be a ref's call) the top bot would get points for hanging. |
#13
It says right in the scenerio that if you remove either robot the other would be considered hanging, therefore they would both score points
#14
The way I see it, Redabot is definitely NOT hanging. That's not in question at all.
What is in question is Bluabot's method of descent. IF BLUABOT SLAMMED DOWN ON REDABOT: -No points for Redabot, as it's not hanging. -50 points for Bluabot, as it is defined as hanging in the scenario. -Warn Bluabot for getting a too rough, penalize if there's some real damage IF BLUABOT EASED DOWN ON REDABOT IN A SLOW, CAREFUL MANNER TO PREVENT DAMAGE: -No points for Redabot, as it's not hanging. -50 for Bluabot, as it would be hanging (given in scenario). -No warnings to Bluabot, as it's exhibiting a legitimate strategy and showing enough GP by not intentionally trying to damage Redabot. (Besides, Redabot is supposed to be built to withstand "vigorous interaction.") |
#15
| YMTC - No battery plugged-in | SilverStar | You Make The Call | 15 | 10-04-2004 13:12 |
| YMTC: Redabot grabs rail | Natchez | You Make The Call | 10 | 10-04-2004 12:16 |
| YMTC: Redabot accidentally breaks goal | Natchez | You Make The Call | 9 | 10-04-2004 12:11 |
| YMTC: Bluabot and Redabot hanging? | Natchez | You Make The Call | 15 | 23-03-2004 01:42 |
| YMTC: Bluabot dies while pinning | Natchez | You Make The Call | 17 | 21-03-2004 11:33 |
