Go to Post Sometimes we over react to things, and thats where a PM can clear a bunch of confusion. - mechanicalbrain [more]
Unread 05-04-2004, 22:05
JoshJ JoshJ is offline
#0316 (LuNaTeCs)
JoshJ is on a distinguished road
Send a message via AIM to JoshJ
Re: independant 4 wheel drive
For simplicity, like its been said, you can just link each side with chain and sprockets or gears, etc
For driveability, i would use a gyro to give you steering feedback and have it adjust ur drives(not that i have any experience with them, but that seems to be the general trend around here)
For traction, maybe you could use a non powered wheel with an encoder on each driving side. That way, if a wheel slips, you can slow it down to the speed of the non powered wheel, (or just above it, depending) until the two speeds match, then you know that you are getting grip, and are good to go. Let me know what you think
-Josh
trentonDrive.c: our joystick/wheel drive code gnormhurst Programming 16 03-02-2005 14:40
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
Tank Stearing - 4 wheel drive Joe P Technical Discussion 12 04-03-2003 23:05
wheel drive Greg Needel Technical Discussion 3 29-01-2002 12:12
