Go to Post They improvised. They overcame. They persevered. And they succeeded. ... I cannot remember being more proud of a group of students with which I have been associated. - dlavery [more]
Unread 06-04-2004, 10:11
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Wonderful world of standards.
I have been wondering about this for a while now. In a lot of my books I read I see mention of ANSI. ANSI C, ANSI numbered roller chain, and ANSI safety signs are all of things I have seen that have this designation. Can someone tell me more about the wonderful world of standards and these interesting organizations?
Unread 06-04-2004, 10:56
Re: Wonderful world of standards.
Adam,
Have you tried here... http://www.ansi.org/ ?
Unread 06-04-2004, 11:01
Leo M Leo M is offline
#0384 (Tucker Tigers)
Leo M is just really niceLeo M is just really niceLeo M is just really niceLeo M is just really niceLeo M is just really nice
If you like standards - and you have to be a very "special" type of person to really get off on standards - try the following :
ANSI.org; ASTM.org; STEEL.org; ASME.org, and IEEE.org, and the Underwriter's Laboratories site - I don't have that one right now.
If you really like this stuff, you may have a career in government.
Leo M.
Unread 06-04-2004, 17:05
Adam Y.'s Avatar
Adam Y.
no team (?????)
Adam,
Yeah but all I know from that site is that it is an organization that makes standards. As an engineer how much do you follow the above is what I am asking?
Unread 07-04-2004, 07:58
Adam,
The object of having "standards" is that all of us should follow them. By having materials that meet standards we know that whowever manufactures 80/20 aluminum it will all be the same. A 10-32 screw will fit anyone's 10-32 nut, #10AWG wire will be the same size regardless if it manufactured by Belden or by XYZ Wire Co. If you search around for standards on particular parts or materials you can easily find what the specs are. The payment plan is for those manufacturing firms that need to make parts to fit a certain standard and need the entire document relating to that part of the standardization. Standards are very important and they make life simpler by allowing us to all speak a common language. Think of what is what like when a colonial cannon maker needed a bolt to fit in a 1/4" hole. First, what standard did he use for an inch and if it was the same inch in all of the colonies, what then described the threads, length and material? Now the same maker simply specifies he needs a 1/4-20 x 2" stainless steel bolt and he has 20 sources to choose from.
Unread 07-04-2004, 08:02
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
The same thing applies with things like ANSI C. All major compilers follow that standard, meaning that if you write a program with one compiler, if you stay within ANSI C, you know that it will compile under a different compiler. (That's the theory anyway... )
Unread 07-04-2004, 09:45
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
If you like standards, check out the w3c site (basically, web standards). And, as the web is a bit newer than say the need for a 1/4" screw in cannons, you'll see there isn't so much of an agreement as to standards (everyone wants to set them, becuase there is power and money to the owner). Oh, and some major web browsers (not to name names, ****soft), don't necessarily support the standards. If you're interested in the idea behind the wonderful world of standards, looking up HTML or XML or etc. specifications, you'll find a load of controversy and debate.
Unread 07-04-2004, 17:15
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
If you want to buy from someone else, sell to someone else or interoperate with someone else, then you need to follow standards. Additionally, standards make it easier for a team of people to work on a project. Why does FIRST spell out the rules for wiring the electronics in your robot? They are following a standard so that your robot can be inspected to insure it is safe. Electricity doesn't care if the wire color is red or black, but when you need to try to figure out why something is not working, would you rather have wiring that follows the standard, or try and troubleshoot an electrical system where the person who wired it did not wire red to (+) and black to (-).
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 07-04-2004, 18:09
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Another couple of websites:
The National Institute of Standards and Technology
The International Organization of Standards
NIST is cool, but their website can be a pain, and the ISO charges money for documentation of their standards, as far as I can tell, but if you're interested in standards, they're pretty good.
Oh, there're also many websites who list RFCs. www.rfc.net seems to be a pretty good starting point.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
The wonderful world of Flash Chris P Website Design/Showcase 6 27-01-2003 13:14
What's 'Right' with this world archiver 2000 2 23-06-2002 22:37
PERFECT WORLD archiver 1999 3 23-06-2002 22:20
FIFA World Cup Manoel Chit-Chat 19 06-06-2002 14:12
FIRST Spirit to the world!!! Tomas General Forum 3 12-04-2002 13:25
