Go to Post The engineer mentors ARE part of the team, equals with the students in every aspect - KenWittlief [more]
Unread 06-04-2004, 13:29
Vu2000 Vu2000 is offline
Midnight Mechanic
None #0812 (Midnight Mechanics)
Vu2000 has a spectacular aura aboutVu2000 has a spectacular aura about
Send a message via AIM to Vu2000 Send a message via MSN to Vu2000
Re: independant 4 wheel drive
We've tried using 1 motor on each side to get 4 wheel drive, and we've never had a successful drive train. What we used was the drill motor in the middle, and had a long chain running from the front sprocket to the back sprocket and tensioners on both sides of the drill motor.
The problem with that is: since your not running the chain from front to rear, you don't have enough wrap around your sprocket. An ideal drive train probably has around 140-150 degrees of wrap. Because our drive train did not have enough wrap, the sprocket and chain would engage well and the sprocket would always slip when we drive, and it would make that weird buckling noise because of the slippage.
We have since tried 2 wheel drive and it works better than before... next year we'll go back two 4 wheel drive but maybe this time with a double sprocket or 4 motors?
Peace up; A-Town Down
2006 So Cal Chairman's Award!!!
2005 So Cal Chairman's Award
2005 So Cal Safety Honorable Mention (safety captain)
2004 Championship Engineering Inspiration
2004 So Cal Engineering Inspiration
trentonDrive.c: our joystick/wheel drive code gnormhurst Programming 16 03-02-2005 14:40
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
Tank Stearing - 4 wheel drive Joe P Technical Discussion 12 04-03-2003 23:05
wheel drive Greg Needel Technical Discussion 3 29-01-2002 12:12
