Go to Post The best revenge is living well. - gblake [more]
Unread 24-03-2004, 18:02
Allison Allison is offline
AKA: Allison Phelps
FRC #1024 (Kil-A-Bytes)
Allison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant future
switching modes
in STL we only had one autonomous mode so we could only set up on the left side of the field. i have written more programs but i don't know or understand how to write the code to switch between different modes. i have written 4 mode (includes right and left). i would prefer to be able to switch modes from the OI but am open to doing it anyway possible. i need something i know will work since we accedently left the robot controller on the robot so i have no way of testing it before our next regional.
thankyou so much
allison
Unread 24-03-2004, 19:24
miketwalker miketwalker is offline
Robot Lifeguard
FRC #1902 (Exploding Bacon)
miketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond repute
Send a message via AIM to miketwalker
Re: switching modes
Well, I believe the OI can't send data inputs to the RC during autonomous. However, if you put 2 switches on your RC and plug them into the "Digital Inputs"... simply make one code, with all 4 modes on it. Make one switch the side switch (i.e. when on run Left side, when off run Right side code) and the other switch can choose between 2 modes... if you want to do 4 modes like you said, you can do more digital inputs with switches to choose. Then just in your code make IF loops to pick the code. Tell me if this makes sense, I'm kind've tired so I don't know if I make any sense.
Chopsaw? Chopsaw.
Unread 24-03-2004, 19:50
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: switching modes
You can in fact use the OI [edit] apparently im wrong about the rest of what i said i trust 10inthecrunch's explanation better than my own [/edit]
Team 1257
Unread 24-03-2004, 19:58
10intheCrunch's Avatar
10intheCrunch 10intheCrunch is offline
Who's John V-Neun?
AKA: Alex Baxter
None #0254 (Cheesy Poofs)
10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough
Send a message via AIM to 10intheCrunch
Re: switching modes
We use switches this year on our OI. The robot and OI are in full communication when you set them out on the field (just PWM and relay outputs are squelched), and inputs are only set to neutral when you go into autonomous. So, to do this: figure out which digital inputs you want to use, and in your program, capture the *previous* values of those inputs (the program makes one more sweep with neutral values, so you need the good ones from before that).
Basically just set up variables for the previous values and set them at the bottom of User_Routines, and in your Main function, create a variable that amalgamates those variables. Now you have one variable you can use for a switch statement in your autonomous code.
PM or IM me if you have trouble getting it to work, its a little difficult to explain in a static post .
~Alex Baxter
Programming, Arms operation, Team 254
Unread 24-03-2004, 20:18
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
Re: switching modes
Last year we used a switch wired into the RC to tell whether we would turn left or right. I am not sure about whether or not we used one program, or had it switch between two programs. I was not the programmer last year, but I may have heard from our previous programmer that it switched between two different programs.
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
Unread 06-04-2004, 12:54
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: switching modes
And it turns out that Main.c is messed up. when Auton is set, it does one run of Process_Data_From_Master_uP() before doing Auton. I'll post a fix if anyone wants it.
Unread 06-04-2004, 12:59
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: switching modes
Yeah, I had noticed that. I actually fixed it in our code. Personally, I feel that the framework they gave us was badly designed, but whatever.
Unread 06-04-2004, 13:30
AKA: Jamie Bliss
Re: switching modes
Better than nothing.
Unread 06-04-2004, 13:37
AKA: Jamie Bliss
Re: switching modes
Here's what we're talking about:
void main (void)
#ifdef UNCHANGEABLE_DEFINITION_AREA
  IFI_Initialization ();        /* DO NOT CHANGE! */
#endif
  User_Initialization();        /* You edit this in user_routines.c */
  statusflag.NEW_SPI_DATA = 0;  /* DO NOT CHANGE! */
  while (1)   /* This loop will repeat indefinitely. */
#ifdef _SIMULATOR
    statusflag.NEW_SPI_DATA = 1;
#endif
    if (statusflag.NEW_SPI_DATA)      /* 26.2ms loop area */
    {                                 /* I'm slow!  I only execute every 26.2ms because */
                                      /* that's how fast the Master uP gives me data. */
      if (autonomous_mode)            /* DO NOT CHANGE! */
        User_Autonomous_Code();    //You edit this in user_routines_fast.c
      Process_Data_From_Master_uP();  //Used to be before the if
    Process_Data_From_Local_IO();     /* You edit this in user_routines_fast.c */
                                      /* I'm fast!  I execute during every loop.*/
  } /* while (1) */
}  /* END of Main */
Alternative autonomous modes Jon Reese Programming 1 14-01-2004 13:17
high-low gear switching archiver 2001 8 23-06-2002 22:39
Team 45 Dual Motor Gear Switching Assembly WorkThoseBuns Motors 1 20-03-2002 19:27
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
[white paper] Dual Motor Gear Switching Assy Brandon Martus Motors 0 29-06-2001 12:56
