Go to Post I just think that if we are going to have rules intended to level the playing field, they shouldn't hurt teams that put the effort in to go the extra mile. - Dave Scheck [more]
Unread 06-04-2004, 16:46
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Re: independant 4 wheel drive
Originally Posted by Vu2000
We have since tried 2 wheel drive and it works better than before... next year we'll go back two 4 wheel drive but maybe this time with a double sprocket or 4 motors?
As far as I can tell, the best solutions to your problem are to either use a double sprocket on the output shaft of your gearbox, as you said, or to snake the chain around the output shaft using idle sprockets. In 2001, team 254 did this. The picture should be nicely indicative of what I mean.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
trentonDrive.c: our joystick/wheel drive code gnormhurst Programming 16 03-02-2005 14:40
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
Tank Stearing - 4 wheel drive Joe P Technical Discussion 12 04-03-2003 23:05
wheel drive Greg Needel Technical Discussion 3 29-01-2002 12:12
