Go to Post Diversity means diversity in ideas too. Some of the robots from the singapore competition might have employed strategies or ideas that we may not even have come up with in North America. - J Flex 188 [more]
Unread 06-04-2004, 22:02
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Using the Microsoft Sidewinder Controller
On a slight side note: You can use standard game controllers. Here are the offical specs for DB15 game port:
Pin NonMIDI MIDI
 1  +5v     +5v
 2  A-1     A-1
 3  A-X     A-X
 4  Ground  Ground
 5  Ground  Ground
 6  A-Y     A-Y
 7  A-2     A-2
 8  +5v     +5v
 9  +5v     +5v
 10 B-1     B-1
 11 B-X     B-X
 12 Ground  MIDI Rx
 13 B-Y     B-Y
 14 B-2     B-2
 15 +5v     MIDI Tx
Just remember that pins 5, 8, 9, & 15 are special on the OI.
Does the Sidewinder use MIDI? Try setting it up as some other kind of controller.
Microsoft Visual SourceSafe Madison FIRST-related Organizations 7 13-10-2004 21:18
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
C controller Rorschach Kit & Additional Hardware 1 29-10-2003 19:21
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Any pratical use for Microsoft Visual Studio .NET Pro Kyle Fenton General Forum 11 28-01-2003 16:59
