Re: Spazing Robot
I've asked around about just how important cooling is for the victors.
Every responese I've heard so far is: In 2 minutes, at the loads we opperate, no one should ever be able to smoke a healthy victor with our with out the fan running. All the same, the strong recomendation is to wire the fans to the 12v+ and negitive terminals. Make sure that the fans' red lead is on 12v+. They will either not function or not function well if hooked to reverse polarity. There is no good reason to wire the fans to a seperate circuit, and plenty of reasons not to. I suspect that in the process of rewiring the fans, you fixed the real problem. My guess would be a loose terminal screw that was causing intermentint contact and possibly overheating. -Andy A. |
| Building more than one robot / expanding the "season" | Mr. Van | General Forum | 25 | 19-02-2004 17:51 |
| Controlling a FIRST robot with a Lego RCX Controller? | archiver | 2001 | 5 | 24-06-2002 04:19 |
| Are you willing to let others take picture of your robot? | Ken Leung | Robot Showcase | 21 | 10-04-2002 22:50 |
| Kamikaze Robot Strategy... | Joe Johnson | Rules/Strategy | 30 | 07-04-2002 21:42 |
| Calling all Lawyers... ...Define "all parts" | Joe Johnson | General Forum | 10 | 13-03-2002 15:12 |
