Go to Post Things that get said on the field should stay on the field. - Bongle [more]
Unread 07-04-2004, 10:11
Hinkel Y.'s Avatar
Hinkel Y. Hinkel Y. is offline
FRC #0188 (Woburn Robotics)
Hinkel Y. has a spectacular aura aboutHinkel Y. has a spectacular aura aboutHinkel Y. has a spectacular aura about
Send a message via MSN to Hinkel Y.
How to design a gearbox?
Does anyone know any book titles or websites that could teach me how to design a multi-motor gearbox (with or without a tranny)? Like a gearbox design for dummies...
Unread 07-04-2004, 10:19
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: How to design a gearbox?
http://www.howstuffworks.com should be a good start. I have the physical book, and it has descriptions of both manual and automatic transmissions. It probably covers gearboxes as well.
Unread 07-04-2004, 10:37
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
There are many white papers on here about these sorts of subjects. I think your best bet will be to go with one of the gearboxes already on here. I can speak from experience when I say that designing a tranny from scratch is pretty darn hard. I just tried modifying one and managed to screw it up.
If you're trying to make one yourself, though, Martin Sprockets has a pretty good guide to sizing gears in their eCatalog. Also, I recommend Mark's Standard Handbook for Mech E's, except it's rather expensive and filled with stuff you don't need. Machinery's handbook could also be helpful. I'm unsure there is anything that specific as to tell you exactly how to design a tranny, though.
Finally this white paper seems like it would be the most helpful:
JVN's FIRST Mechanical Design Calculator
Unread 07-04-2004, 12:33
FadyS.'s Avatar
FadyS. FadyS. is offline
AKA: Fady Samuel
#1246 (Agincourt Robotics)
FadyS. is on a distinguished road
Ohh, the horrors!!!! Designing a gearbox is a pain. We had the hardest time designing a gearbox that would actually work. Tristan Lall helped quite a bit but we had to make modifications because we decided to use 24" bike wheels. We found that to avoid having two stages of sprockets we had to make very significant modifications. So we did design it and we got it machined but we had lots of trouble with it at the competition. First of all, they turned out to be really heavy with all the 72 tooth gears we had in there. Secondly we had problems with the press-fit bearings falling out. Balancing weight, speed and torque for the very first time was a very big challenge for our two 17-year-old mobility people.
EDIT: We had planned to go up the 6" side of the platform and we had calculated the torque required to do that given the estimated weight distribution of the robot. So we needed more than around 110 Newton metres of torque after taking into account 70% efficiency per gearbox.
Unread 07-04-2004, 13:15
LauraN's Avatar
LauraN LauraN is offline
Holder of the Missile Keys
FRC #0097 (RoboRuminants)
LauraN is a splendid one to beholdLauraN is a splendid one to beholdLauraN is a splendid one to beholdLauraN is a splendid one to beholdLauraN is a splendid one to beholdLauraN is a splendid one to behold
Send a message via AIM to LauraN
This may sound corny, but...
In all seriousness, pull up Amazon.com and search for robotics. You'd be amazed. A teammate and I did this once in school and we were like...drooling at all the cool books we wanted to buy. Sad, I know. =)
There IS a book called "Robot Building for Dummies," and there's also an entire series (Robot DNA Series) dedicated to the subject, with one entire book called "Building Robot Drive Trains." I'm not sure if it has much info on gearboxes specifically, but it does have lots of info about which motors to use and how to mount them. (My copy was recently ordered and is now in the mail. )
Don't you love that crazy Canadian Regional?
http://www.firstcanadianregional.org...ces/Workshops/
Howstuffworks.com and the white pages are a good place to start as well. I also suggest getting yourself some legos and playing around with them. You can read as many books as you want, but nothing beats actually putting gears together to get a general idea of how it all works.
Ask other teams. If you're in Atlanta, just drop by a random team's pit and they will probably be more than happy to show you what they did and how they did it. If you're stuck at home like us while everyone else has fun at Nats, look up local teams that may be able to help you.
Books are cool, but I would look into real hands-on experience as well.
-Laura Nicholson
Team 97 (RoboRuminants) Mentor
Team 30 (FURY) Alumna
Unread 07-04-2004, 14:06
KyleGilbert45's Avatar
KyleGilbert45 KyleGilbert45 is offline
KyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant future
I've heard these have helped some people in the past....
Technokat Archived Documents
You might wanna look at Shiftonfly.pdf , Dualmotor.pdf , and 6motor.pdf
Even though they really are not a "teaching tool" for designing gearboxes they might give you some good ideas.
Unread 07-04-2004, 15:00
Bharat Nain's Avatar
Walk up to Barnes & Nobles and look in the science section. There should be a whole lot of information there. Although, having a mentor helps more.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 07-04-2004, 15:25
aaronbr28040's Avatar
aaronbr28040 aaronbr28040 is offline
AKA: Aaron Bradshaw
#0900 (Team Infinity)
aaronbr28040 is just really niceaaronbr28040 is just really niceaaronbr28040 is just really niceaaronbr28040 is just really nice
Send a message via AIM to aaronbr28040
If you need to know standards and basics of gear train design, go to this website :http://www.sdp-si.com/catalogs.htm . Their books of small standard drive compenents and the Drive Component Design textbook are both really helpful. The textbook has all of your tolerances for press fits and helps you learn the basics of backlash etc. in a drive train. It also has a special section on robotics in the back. All of the books can be viewed online or ordered.
Hope that helped some.
Aaron
@North Carolina State University
Team 900
North Carolina School of Science and Mathematics
AIM:aaronbr28040
Unread 07-04-2004, 18:40
Here, I found something useful:
http://www.firstcanadianregional.org.../Gearboxes.pdf
Another good place to look is www.google.com . There's a LOT of stuff about gearboxes.
-Bharat
-= Bharat Nain =-
Unread 07-04-2004, 18:56
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
I have both Building Robot Drive Trains and Programming Robot Controllers from the Robot DNA series, and I have to say, they're both awesome. My copy of the former isn't right next to me, but it contains information on everything from basic gear design and fundamentals, to DC electric motor designs, to relative / absolute position encoders, to how you can (with a screwdriver and a saw) modify a standard hobby servo to act as a motor (detail about how to remove the hardstop and disconnect the potentiometer, if I recall correctly). Anyway, I highly recommend these books.
Also, as a text reference, I think you should look into a book from Stock Drive Products (SDP-SI) entitled Design and Application of Small Standardized Components. You can order it for free from SDP's website, and I think it's a great little resource. Don't let the name mislead you, it contains information about topics from gear design, to gear train design, to how to heat treat steel, to effeciently and effectively machining materials, to, well, a lot of other great stuff. Did I mention it's free? I did? Well, it's still free. They'll ship it to you with every single one of their catalogs for less than a dime ($0, in fact).
I love these books.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 07-04-2004, 19:31
Ryan F.'s Avatar
Ryan F. Ryan F. is offline
Ryan F. is a jewel in the roughRyan F. is a jewel in the roughRyan F. is a jewel in the rough
Small parts has a good basic gear guide on their site. It gives you much of the information needed to design a simple gearbox.
Unread 07-04-2004, 21:11
Generator of Entropy
FRC #2973 (The Mad Rockers)
You will absolutely want to sign up for the conferences on motors and drive trains at nationals - take notes, ask questions, and get a copy of the presentation material.
Unread 07-04-2004, 21:31
Hinkel Y.'s Avatar
How do I sign up? This is the first time I'm going to the nationals...
Unread 07-04-2004, 22:15
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Team 116's dual speed/dual motor gearbox whitepaper
Good luck with your gearbox
Unread 07-04-2004, 23:06
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Originally Posted by TeknoBramha
That is an excellent presentation. In addition to that, this may sound stupid but my best resource for gearboxes (and everything else) has been www.chiefdelphi.com You can get more from this place than you ever imagined, and not just in the whitepapers. Me without ChiefDelphi is like a historian without history. This is a real top quality community that can teach people more than any other single place I know.
TechnoKat design usage, communicated with judges Andy Baker General Forum 13 24-03-2004 17:37
Design Sharing Rod General Forum 32 14-01-2004 22:00
How do you design your robot? Gui Cavalcanti General Forum 23 16-11-2003 18:33
A question about gearbox design . . Frank(Aflak) Technical Discussion 14 02-10-2003 14:57
gearing design calculation question caffel Motors 4 24-03-2003 17:34
