Go to Post Do what you do well and I'm sure there will be much hope in your future! - Collmandoman [more]
Unread 08-04-2004, 01:26
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
Re: Chain Drive Question
Another way to tension chain besides Slotted wheel mounts and tensioners is an adjustable gearbox.
This year we built our gear boxes on the frame with a sandwhich mount and shims. WHen the chain would get loose we could slide the gear box up or down ( depending on location of the 2nd sprocket ) and tension that way. It worked out really well for us. It ended up being much easier than sliding every wheel like we used to in old chain drive designs. Just loosen a few bolts, slide, tighten the bolts up again and walla Tight chains.
Its probably late to consider something like this but Its just an interesting idea that works really well.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
XP Hard Drive Space Question Raven_Writer Chit-Chat 13 07-08-2003 16:38
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
question about one joystick drive programing james700 Programming 13 29-01-2003 14:49
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
