Go to Post It's a club if you have a bunch of people who hang out and do nothing - It's a team if all you all work together and cooperate to win. - Tytus Gerrish [more]
Unread 05-04-2004, 21:12
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Re: Chain Drive Question
Just some friendly advice (for next time) go find the formula that will tell you the center to center distance of the sprockets so that the chain fits and no tensioner is needed
Err that is nice and all but I really doubt you would be able to get an answer that would really work nicely. You are probably still going to need tensioning. Anyway here goes the process.
Chain Length=L
Center Distance(Distance between sprokets center)=C
Pitch Diameter of Larger Sprocket=D
Pitch Diamter of Smaller Sprocket=d
Errr wow is that confusing or what. I hope someone can find a simpler form than what I just typed. Instead of typing it I scanned them. Unfortunately its sideways.
Unread 06-04-2004, 02:46
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Chain Length=L
What type of units is L in? Where exactly do you measure the length of chain? Overall length or between pins or what? Or do you count the number of links?
Unread 06-04-2004, 03:49
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
DANGER: Shameless Plug!
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 06-04-2004, 09:27
Adam Y.'s Avatar
Adam Y.
no team (?????)
Might as well borrow a bit more from my book.
These equations will provide physical lengths. To determine the correct chain length and center distance, use this procedure:
1)Estimate what the center distance (C) should be.
2)Chain lengths are based on an even number of pitches. To determine the number of pitches, divide the chain lenth by the pitch length. If the number of pitches of the chain is not an even number, round up or down for an even number.
3)Multiply this result by pitch length to get the final physical length of the chain.
4)Plug the pitch length into Equations 19 and 20 to calculate the center distance between sprokets.
The book was a whee bit vague as to what units L was in. Im guessing that it should be whatever untis the pitch is in. Metric for metric chain and the same for American chain.
Unread 06-04-2004, 20:41
maclaren maclaren is offline
AKA: Dexter
FRC #0997 (Spartan Robotics)
maclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of light
Oh yes I forgot to mention something FRICTION IS YOUR ENEMY. Gloified plastic chain gaurds are a large drain on efficeny. We used idler sprockets which have built in bearings. We took the idler sprockets and mounted them to a small piece of 80-20 and then bolted the slide to another piece of 80-20 and you simply slide the idler sprocket and then tighten the bolts.
It's simple and easy.
Unread 06-04-2004, 20:44
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Oh, right, that.
One word: WEIGHT.
Unread 06-04-2004, 22:07
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I'll toss in my two cents. In every chain length formula I've seen, L is is actually in number of pitches, as opposed to and measure of length. and the chain doesn't HAVE to be an even number of pitches, it's just good practice not to use offset links.
Unread 07-04-2004, 00:15
AKA: Dexter
Originally Posted by Astronouth7303
Oh, right, that.
One word: WEIGHT.
Yeah that's true weight is allows a problem in first however that is also why you follow good engineering practices.
Just for the person that posted the picture of their teams robot using short section of chains. AVOID CAST IRON LIKE THE PLAUGE and you will save at least 1-2 lbs per bearing.
The best way to remove weight is to go to aluminum axles and and fixed axles with live wheels. It takes a little effort but could give you at least 5-8 lbs back out of your drive train. Also the wheels will be easy to install, remove, and repair.
Unread 07-04-2004, 15:25
Dick Linn's Avatar
no team (Synergy)
A couple of times, we've mounted each drill motor and small sprocket shaft on an aluminum plate. This plate has slotted holes and can be moved in relation to the drive wheel to tension the chain when necessary. We can also use washers between the plate and the chassis rails to get additional range (yeah, the slots weren't long enough...). Keep the chains lubed, snug and aligned and you'll have less chance of breaking a chain when it tries to climb up and over the sprocket teeth. Also avoid tiny sprockets.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 08-04-2004, 01:26
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
Another way to tension chain besides Slotted wheel mounts and tensioners is an adjustable gearbox.
This year we built our gear boxes on the frame with a sandwhich mount and shims. WHen the chain would get loose we could slide the gear box up or down ( depending on location of the 2nd sprocket ) and tension that way. It worked out really well for us. It ended up being much easier than sliding every wheel like we used to in old chain drive designs. Just loosen a few bolts, slide, tighten the bolts up again and walla Tight chains.
Its probably late to consider something like this but Its just an interesting idea that works really well.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 08-04-2004, 02:18
Grommit Grommit is offline
#0115 (Monta Vista Robotics)
Grommit will become famous soon enoughGrommit will become famous soon enough
Send a message via AIM to Grommit
Yes, Travis is quite right, I neglected to mention that our wheels have always been mounted such that they could slide for us to tension them. What I intended to explain was that spring tensioning is not the only solution, and that slots are a convenient alternative.
Also, note that Bosch extrusion particularly has very easy, built in slots that hold well (if you are using 30mm X 30mm, that is). There are T-Blocks available (at great expense ) that make mounts very solid.
Even if you do not wish to use Bosch, and you don't like your chassis to have a big aluminum plate base, you can still use slots. Take your welded chassis and bold on a plate, almost as a gusset, but with a big slot and two smaller ones on each side to hold the wheel and two mounting blocks. The slots on the side allow you to adjust the mounting block position. But it gets better: many teams have trouble tensioning this, because it takes two people: one to pull on the wheel and one to tighten, and it just isn't fun. The clever plan is to use a custom tool. Mount a block with a threaded hole in front of the mounting block slots. Use a larger hold for greater control and ease of use. Then take a long bolt and put it in the thread, so that when you tighten the bolt, it will push on the mounting block. Then you can even use a drill (on very low clutch setting, maybe as low as 11 or so) to tighten the mounting blocks for you, and they won't bounce back. VERY useful for quick tightening jobs.
Shrenik Shah
Engineering Director
Team 115: Monta Vista Robotics
Congratulations to Mr. Shinta for winning Woodie Flowers at Silicon Valley!
Unread 09-04-2004, 13:55
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
I'll add in another plug for the adjustable sprocket-box that 190 has used the past few years:
The black line is the chain, the two larger sprockets are idlers, and the smaller sprocket is attached to the motor. On the bottom of the image, you can see the chain returning. By tightening or loosening the bolt, we can adjust the tension. Also, this design assures that we have a full 180 degrees of wrap around the motor's sprocket (this image isn's quite accurate).
The other nice thing is that by flipping this design around on the other side of the robot, and driving the lower part of the chain, we can have both motors driving in the same direction when we drive forward:
EDIT: Just to clarify, on each side, there are two identical lexan plates, one on either side of the sprocket. Therefore the adjustable sprocket is actually supported by two bolts, which need to be adjusted together.
Zan Hecht
Unread 09-04-2004, 14:15
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Like that idea, we considered it but could not figure out a way to get the sprockets attached to the live wheels, Skyway had a bike wheel that was close but it had a coster break installed and was to large anyway. Had to go with the live axles. Last year we got cantiliverd (sp) axles bent, this year we over compensated. We just finished a design in inventor for a 45 tooth #35 chain Aluminum sprocket, With out the weld that holds the hub on inventor says weight is .317lbs or 5.072 oz our target was 6 oz or less.
Unread 09-04-2004, 14:24
ahecht's Avatar
'Luzer'
AKA: Zan
Originally Posted by Biff
Like that idea, we considered it but could not figure out a way to get the sprockets attached to the live wheels...
If you were using the kit Skyway wheels, MMH Ventures sold a hub kit that allowed you to attack sprockets to wheels. You can also make your own hub that clamps onto the wheel spokes, but that requires a bit of machining work.
Zan Hecht
Unread 09-04-2004, 14:29
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
Machinery's Handbook has all the chain formulas you could want, plus an explanation. Units are usually in chain pitches.
But...
Chains have tolerances associated with the links. As your chain gets longer, the tolerance stack up makes the chain center distance formula less accurate. Even for a moderate tolerance, the droop in a chain will be too much. Idler sprockets, tensioners, rubbing blocks become a must.
Chains also wear with use. So, even if you get the center distance correct in the first place, over time, you will start to see increasing loopiness.
In short center distances (say 2" to 6") you won't see these effects too drastically. But, in longer distances, the situation gets worse and worse.
With the push towards multi-drive motors in a drive system, we have gone with direct drive on all of our wheels over chain drive. We take a hit in the weight department, but we gain in the reliability department and in the manufacturing department.
XP Hard Drive Space Question Raven_Writer Chit-Chat 13 07-08-2003 16:38
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
question about one joystick drive programing james700 Programming 13 29-01-2003 14:49
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
