Go to Post I think overcoming obstacles together builds a stronger team. - MissInformation [more]
Unread 08-04-2004, 03:30
PBoss PBoss is offline
PBoss is an unknown quantity at this point
PBasic Probelm
Hi,
I have 3 push buttons that I am using as a switches. I am using last year's robot controller. What I want to do is when I press a button once, I want it to be like a toggle button. When I press a button, I want the controller to run a sub routine. That is simple, I know, but here is the catch:
If while running the sub-routine, a second button is pressed, I want the RC to ignore the second button. When the RC is done executing the subroutine, then I want it to be able to recieve a signal from any other button, but not until it is done executing the first sub routine.
Also, I forgot, in PBasic, is this how you used to do sub routines?
IF condition THEN
gosub FIRST
ENDIF
FIRST:
'code
Is that all there is to it or do I have to declare the sub routine in a different way or end the sub routine in a different way. I'll appreciate any help.
Obscure PBASIC for RoboEmu rbayer Programming 1 28-03-2003 23:57
PBasic 2.5 vs. 2.0 Anthony Kesich Programming 6 09-02-2003 22:06
PBasic Question Melissa H. Programming 28 17-11-2002 18:53
Output voltage in PBASIC diego25 Programming 7 31-01-2002 22:50
Another PBASIC Question Ian W. Programming 4 31-01-2002 21:36
